01-18-2022, 09:36 PM | #1 |
Pistons for a steel sleeve engine
I recall reading that 39-40 99A steel sleeve engines came with steel pistons. When I took mine apart it had aluminum pistons, I know it had been apart some time in the past as the crank was .040 under and the cam journals .010 under. My plan is to use A set of 8BA pistons that I already have. The engine will go into my 35 sedan which will be a local cruise night car with some occasional weekend drives in the country. Will the aluminum pistons be a problem-?
01-18-2022, 09:57 PM | #2 |
Re: Pistons for a steel sleeve engine
If your engine is a steel sleeved 221 3-1/16 bore you will need to remove the sleeves and bore the cylinders to accept the 8 b a 239 pistons, so the pistons will be against the cast iron cylinder walls.
01-18-2022, 10:54 PM | #3 |
The aluminum pistons will give no trouble provided clearances are correct
01-19-2022, 07:52 AM | #4 |
what rods/crank are you using? going to do two engines like that soon.
01-19-2022, 05:40 PM | #5 |
Mike |
