Old 10-18-2019, 05:38 AM   #1
Forddan
Default 1931 steering column brace bracket installation in......
Hi
I need to install a 1931 steering column brace bracket in my early 1929 Ford Tudor as I have a small gas tank leak to solve.
Anyone have some pictures to share on how to attach/install it.
This is the steering bracket I have to install:
Thank you !!
Daniel
Forddan is offline   Reply With Quote
Old 10-18-2019, 10:31 AM   #2
duke36
Default Re: 1931 steering column brace bracket installation in......
Did you try to see if it fits or can be adapted somehow under the dash rail on your '29 ? That style is used as you state on later cars with 2 tooth steering and bolts to the cross rail mating sections with the dash cover removed for easier access. The projecting pin slips into a recess (hole) in the cross pieces.
Old 10-18-2019, 10:38 AM   #3
alexiskai
alexiskai's Avatar
See this thread for Tom Endy's solution:
https://www.fordbarn.com/forum/showthread.php?t=101806
Old 10-18-2019, 10:50 AM   #4
Benson
Benson's Avatar
To see text on each photo, click on each photo in turn and read text in red color.
Worked well for me.
https://www.fordbarn.com/forum/showp...30&postcount=4
Old 10-18-2019, 11:12 AM   #5
Forddan
Great help !!
Thank you all !!!!
Daniel
Old 10-18-2019, 11:31 PM   #6
w.michael
w.michael's Avatar
See Tom Endy's article published in the Model A News, July-August 2018.
W. Michael
w.michael is offline   Reply With Quote
