01-03-2019, 11:51 PM | #1 |
what about that small lip/shoulder on front of the flywheel for ring gear?
the reason i ask, is this one has about 3/4 of it broken off. see the yellow mark on the front side in the pics. anyone ever had a ring gear fall off? modern flywheels dont have it? i am cutting the blob off the back of a 9" flywheel, and i'd like to use this one as it seems grandma only slipped the clutch on sundays. note the thickness of the red mark on back side, and still a step up to the disc surface in yellow again. i have seen some that that second step is gone after too many grindings from grandma driving other than to church. so...i am tempted to cut the rest of the lip off before balancing. any thoughts from you guys ? thanks, skip
01-04-2019, 07:05 AM | #2 |
Re: what about that small lip/shoulder on front of the flywheel for ring gear?
If I was motivated to use that flywheel I would shrink the ring gear on and install about 4 tiny Dutchman screws at the parting line. I would also remove a minimum amount from the disc wear face. I doubt a good surface finish can be achieved with the amount of chuck overhang pictured.
01-04-2019, 10:59 AM | #3 |
jwl, thanks for the responce. yes, its not a good set up, but its the only way i can reach it as its really too big for the lathe. i do get a nice cut at slow speeds though, and then have the finish done on a grinder, then balance. 8ba's have no lip do they?
01-04-2019, 11:22 AM | #4 |
