Old 04-22-2021, 08:39 PM   #1
marty in Ohio
marty in Ohio's Avatar
Default Bad Rear Axle bearing
What is the symptom of a worn out rear axle bearing?
Marty
marty in Ohio is offline   Reply With Quote
Old 04-22-2021, 09:06 PM   #2
Conaway2
Conaway2's Avatar
Default Re: Bad Rear Axle bearing
Worn-out bearings usually result in noisy operation of the rear axle or wobbly rear wheels. However, there are 7 bearings in the rear axle/torque tube assembly, so some additional detail on what you’re experiencing would help pinpoint the specific problem...although if there is wear in one area, all parts of the rear axle assembly probably need to be inspected.
Conaway2 is offline   Reply With Quote
Old 04-23-2021, 06:47 AM   #3
Bob Bidonde
Bob Bidonde's Avatar
Noise and play.
Bob Bidonde
Old 04-23-2021, 03:43 PM   #4
john charlton
john charlton's Avatar
One quick check is to jack up a rear wheel . Try to lift the wheel up against gravity and let it drop . If the bearing is good there should be virtually no movement . Grasp the wheel and try to twist it sideways there should be no movement if the hub and axle are seated .
John in lovely weather Suffolk County England .
john charlton is offline   Reply With Quote
Old 04-24-2021, 05:31 AM   #5
marty in Ohio
Thanks for the suggestions guys. You can always get a straight answer on Ford Barn.
Marty
