02-08-2012, 04:59 PM | #21 |
Re: Racing Flathead
There is a book about the history of Midgets that has a picture of a reversed port 60 running upside down with some sort of aircraft carb and a dry sump oil system. Could not have been to great because that carb was subject to getting twacked in the slightest altercation.
02-08-2012, 07:54 PM | #22 |
Re: Racing Flathead
If I also recall, in the Tex Smith Flathead book, there is a story about Kong Jackson. There is a picture of his race motor with some trick work done to the ports. I don't have it handy, but I'll try to find it. May not be what we are talking about here, but I'll see.
02-08-2012, 08:01 PM | #23 |
Re: Racing Flathead
I can see the gains of a rev flow flathead such as less heat inside the block since the intake ports are about 6".
I am a believer |
02-08-2012, 09:43 PM | #24 |
Re: Racing Flathead
Book: Petersen's Complete Ford Book copyright 1972.
Article: Those Diggers from Dearborn, by Gray Baskerville. Page: 133 picture 4. Caption for picture 4: "The famed bass-ackward flathead of Jack Nichols and the Smith Bros.(Don & Floyd) was built to use the exhaust ports as intake and intake ports as exhausts. In order to do this, Jack tried 11 reverse rotation cams before Tucker ground him one that worked. The engine, a 3/8 by 1/8 Ford, ran 25% nitro and turned in excess of 7200 rpm. Terminal trap speed in a much modified '32 five-window was (for then) a honkin' 110mph." Last edited by Pamlico; 02-08-2012 at 09:44 PM. Reason: enter author |
02-08-2012, 09:49 PM | #25 | |
Re: Racing Flathead
Scan 62 by Dimitri Lazaris, on Flickr
U.F.R.A ~ United Flathead Racing Association PM For Info! |
07-10-2014, 04:37 PM | #26 |
Re: Racing Flathead
1-26-2014 2-54-55 PM.jpg 1-26-2014 2-58-10 PM.jpg 1-26-2014 2-57-35 PM.jpg 1-26-2014 2-38-56 PM.jpg |
07-10-2014, 05:53 PM | #27 |
Re: Racing Flathead
Now that is a beautiful piece of work!
07-10-2014, 06:56 PM | #28 |
Re: Racing Flathead
That is 1 "Beautiful " lil midget !!! It did live 15 mile up the same road I live on . Bob .....owned it .
I believe that part of the theory for the reverse rotation was to load the left rear tire . Good luck with it & enjoy it . I know this car has a lot of great history !!! Cheers Tony |
07-10-2014, 09:42 PM | #29 |
Re: Racing Flathead
Beautiful, just Beautiful. Sure like to see and hear it run.
07-10-2014, 10:48 PM | #30 |
Re: Racing Flathead
www.youtube.com/watch?v=A2AGSvgEuD0
Not sure if I am doing this link correctly. Here you go Sir! The gentleman I bought it from had it on consignment with RK Motors. |
07-10-2014, 11:09 PM | #31 |
Re: Racing Flathead
Since I have your attention, I would like to ask if anyone can tell me why they made a "Tin" side Flathead in 1937? I have a wood boat from Iowa my wife and I bought 30+years ago which has that motor but marinized. I have never been able to find anyone who knew why they tried that. The welds are beautiful looking! Is it Stainless Steel? It looks like it to me.
07-27-2014, 04:55 PM | #32 |
Re: Racing Flathead
I have seen this one ....... I know it is not a flathead...
Last edited by OddRod; 07-27-2014 at 05:45 PM. Reason: stupid post for this site |
07-27-2014, 05:17 PM | #33 |
Re: Racing Flathead
Some updates are in order for this old post. First the Slider dragster is the fastest and quickest in the 1/4 mile its flathead V-8 has a forth exhaust port coming out the top center of the block dyno horse power is 909. Its owned by Rick Schnell and driven by his son.
The flatfire series of flatheads {there's more than one} built by Dick Landy has all ports coming out the top of the block to date the Flatfire flathead still holds the record at Bonneville I believe its between 301 and 302 MPH. Jimmy Stevens has built a flathead that made the fastest ever pass at Bonneville at over 309 MPH all eight ports also come out the top fo the block. True none of these engines are reverse flow but it shows the potential if one wants to do a ton of work for all out performance. |
07-27-2014, 06:12 PM | #34 |
Re: Racing Flathead
one word, flatfire
http://www.flatfire.com/flatfire_specs.htm I saw this a few days ago. It sure sounds fast. bill |
07-28-2014, 07:18 AM | #35 |
Re: Racing Flathead
These specs are for a 258ci engine??? not 301. I met Dick Landy at Bville back in '02, his pit was next to the Bean bandits. He had several engines in his trailer at that time. Very nice guy.
07-28-2014, 11:08 AM | #36 | |
Re: Racing Flathead
909 hp out of his injected flathead? I'd love to know his tricks. |
07-28-2014, 03:52 PM | #37 |
Re: Racing Flathead
07-28-2014, 03:58 PM | #38 | |
Re: Racing Flathead
Flatfire engine was 301 cubes top speed 302.203 MPH not bad one mile per cube Ronnieroadster Last edited by Ronnieroadster; 07-28-2014 at 07:10 PM. Reason: added ore text |
07-28-2014, 07:37 PM | #39 | |
Re: Racing Flathead
Life is not a spectator sport. |
07-29-2014, 03:37 PM | #40 | |
Re: Racing Flathead
Two weeks we ran my Lakester the small 295 cube supercharged gas burning flathead turned the fastest to date 181.808 MPH slowly gaining speed. Heres a link to the in car video of the run. https://www.youtube.com/edit?o=U&video_id=wMDLLWO9nbQ Ronnieroadster |
