Old 12-15-2020, 09:55 PM   #1
jkcrosson
jkcrosson's Avatar
Default Gas Tank Restoration
Is there anyone currently restoring gas tanks. Mine has old sealant that has started to come off due to corn gas and rust.
Jamie Crosson
1929 Tudor
Looking for an Original 888 Key
jkcrosson is offline   Reply With Quote
Old 12-15-2020, 10:18 PM   #2
Bob from Northport
Bob from Northport's Avatar
Default Re: Gas Tank Restoration
Contact Brent Terry on this site. He has a great shop in Tennessee that can do a great job on your tank
Bob from Northport
Northport, Michigan
Bob from Northport is offline   Reply With Quote
Old 12-15-2020, 10:21 PM   #3
jkcrosson
jkcrosson's Avatar
Thanks
Jamie Crosson
1929 Tudor
Old 12-16-2020, 02:20 PM   #4
ronn
previously, Brent mentioned that he doesnt have the time any longer to do tanks.................
Old 12-16-2020, 05:04 PM   #5
jkcrosson
jkcrosson's Avatar
I had read that
Jamie Crosson
1929 Tudor
Old 12-16-2020, 05:22 PM   #6
chicledrab
moyers gas tank renu Greensburg,Pa. 800 328 9550
chicledrab is offline   Reply With Quote
Old 12-16-2020, 05:23 PM   #7
chicledrab
They do great work. did mine
Old 12-16-2020, 05:40 PM   #8
chicledrab
e paintModel a tanks have baffles SO cut outs have to made to sandblast all interior areas. After sandblasted cutouts are welded back in,and sealer is installed.Then it is baked in an oven which destroys the paint. They then properly sand and primer. Their business card states Lifetme NO RUST Warranty. You then must have tank painted.
Old 12-16-2020, 06:18 PM   #9
McMimmcs
McMimmcs's Avatar
And what is their price ?
Old 12-17-2020, 05:44 AM   #10
updraught
updraught's Avatar
The problem is getting the sealer out. Because of the baffles, unless you cut it open, you'll never be sure you've got it all out.
updraught is offline   Reply With Quote
Old 12-17-2020, 01:24 PM   #11
chicledrab
They charged me $450
Old 12-17-2020, 01:24 PM   #12
chicledrab
Worth it
Old 12-17-2020, 01:37 PM   #13
McMimmcs
McMimmcs's Avatar
If they did a good job it is well worth it.
Old 12-17-2020, 03:09 PM   #14
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
It has been my experience with the "ReNu type" system that they weld several 2" plugs into the tank on the exterior surface to repair the holes that were made to reach the interior sections of the tank. Things may have changed since I inquired with becoming a franchisee for them, but the only way they would put a lifetime warranty on a tank is if they can coat both the interior and exterior. As I explained to the lawyers that owned the ReNU franchise company, coating the exterior of a motorcycle or Model-A tank does no good since they must be painted color.
I won't say my method is better than theirs, only that my method is probably a little more thorough (-since we can access & see 100% of the inside of the tank) ...and with my method, it is "more undetectable" when the tank is completely restored. As far as "not having the time to do them", like everything else going on in this world, we have such a backlog of 'other stuff' to do that the turn-around is longer than what most people want to wait. When folks start complaining about the length of time it is taking, then the easiest way to reduce my stress is to no longer offer that service. If someone is willing to wait, we have been, -and will continue to restore them.
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 12-17-2020, 03:34 PM   #15
whirnot
whirnot's Avatar
I was able to melt the sealer, by filling the tank with acetone and letting it sit for a few days.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 12-17-2020, 03:37 PM   #16
Bob C
I found this picture of one done by Moyer Fuel Tank Renu.
Old 12-17-2020, 03:42 PM   #17
ronn
450 is a bargain.
thanks for clarifying the tank restoration Brent.
Old 12-17-2020, 05:49 PM   #18
Bob from Northport
I have had a number of tanks restored by Brents shop including my own car. He does an excellent job. I have seen the shop and procedure first hand, and it won't get any better.
If the car is worth it, it is worth the wait.
Bob from Northport
Northport, Michigan
Old 12-17-2020, 07:28 PM   #19
updraught
updraught's Avatar
Redcoat, often used by radiator shops is supposed to be removable by acetone.
The others, you pay your money and take your chances...
Old 12-17-2020, 08:07 PM   #20
jkcrosson
jkcrosson's Avatar
Brent, Thanks for the reply. I have no problem waiting. I’ll be in touch.
Jamie Crosson
1929 Tudor
