07-05-2023, 09:56 PM | #1 |
Gates Flex hose # for lower hose on 34
Thanks
Neil |
07-06-2023, 10:06 AM | #2 |
Re: Gates Flex hose # for lower hose on 34
use the lower hose for an 8ba as they have a slight offset that makes a good fit
07-06-2023, 03:38 PM | #3 |
Or just go to your local NAPA and buy straight hose, available by the foot.
07-06-2023, 06:49 PM | #4 |
One thing that REALLY turns me off is the presence of flex hoses on an otherwise well-built car.
DON'T DO IT! |
07-07-2023, 01:35 AM | #5 |
I agree with that statement. Just not correct to have flex hoses on an ORIGINAL vintage Ford. If its modified or Hot Rodded then it does not matter. Regards, Kevin,
07-07-2023, 08:04 AM | #6 |
07-07-2023, 08:39 AM | #7 |
I appreciate and agree with all!!!
BUT still want the number if someone can help Still driving my 34 since 1950. 4 in crank, LZ gears and 47 2 speed. Mech brakes and orig headlights. dont go out at night |
07-07-2023, 09:14 AM | #8 |
07-07-2023, 09:27 AM | #9 |
Appreciate all but still want the number
07-07-2023, 10:22 AM | #10 |
Go to NAPA with the dimensions and speak with a counterman that knows how to navigate an actual book.
The gates book shows hoses by dimensions, both molded and flexible. It truly is that simple. Just curious... why do you desire flex hoses?
"I can explain it for you. However, I can't understand it for you". Last edited by Kube; 07-07-2023 at 01:04 PM. |
07-07-2023, 12:21 PM | #11 |
Listen to Kube. Take a little time, do some research and find the right molded hose. Flex hose is for rookies.
07-07-2023, 07:15 PM | #12 |
yes, yes!
I went, I saw, I bought the T shirt 51 Ford Deluxe Tudor 32 Ford roadster 39 Mercury Towncar |
07-07-2023, 09:03 PM | #13 |
I looked in Gates and Dayco catalogs and the shortest 2" x 2" flex hose they
show is 9 1/2" long. Gates #26507 |
