07-30-2023, 07:41 PM | #1 |
Bushing Removal Tool
Where is a good place to purchase a bushing removal tool to be used in the clutch and brake pedal?
07-30-2023, 08:18 PM | #2 |
Re: Bushing Removal Tool
Only Bratton's sells it.
https://www.brattons.com/BRAKE-CLUTC...uctinfo/11191/ |
07-31-2023, 06:40 AM | #3 |
If you do not have a lathe to make one, then just use a hacksaw blade to cut the bushings in two places (-180° opposite of each other) where it can be removed with a screwdriver. Freeze the new bushings prior to installing to make the installation easier.
07-31-2023, 07:46 AM | #4 |
For very difficult to remove bushings with a single access I have used the following:
Tap the inside diameter and insert a matching screw or bolt that is attached to a dent removal or sometimes called a dent knocker tool. This works very well and minimizes potential damage. |
07-31-2023, 08:28 AM | #5 | |
07-31-2023, 09:46 AM | #6 | |
Good suggestion. I am set-up to do it this way since we do a dozen or more sets a year. Unfortunately, I'm afraid that is going to be kinda expensive since that is such a big thread size. The bushing ID is roughly 0.876", and the bore of the pedal is 0.939". A 15/16"-20 tap and a 29/32nds drill bit is likely going to set someone back around $100.00 to be able to use a bolt threaded into the bushing, ...which if someone is doing it as a once or twice task, I would think using a file or saw blade may still the best (-or most economical) option for most hobbyist. |
07-31-2023, 10:01 AM | #7 |
I bought that tool earlier this year and it works GREAT. I used to hacksaw the old bushings and then dig them out with a chisel. A real pain in the tutu and inevitably a new scar on my hands or fingers was the result - besides a lot of cuss words about the Ford Engineering Department. The tool takes the old bushings right out slick as snot. Putting in the new ones is also a heck of a lot easier now, too. It does help to chamfer the leading edge of each bushing,
If you're going to do more than one set of pedals, this tool is worth the time, sweat and aggravation it saves. Maybe a local Model A club could chip in and buy this tool for the club's war chest. Marshall |
07-31-2023, 10:02 AM | #8 |
Thanks, I suspected that's what the OP was talking about
07-31-2023, 12:49 PM | #9 | |
JayJay San Francisco Bay Area ------------------------ 1930 Murray Town Sedan 1931 Briggs S/W Town Sedan |
07-31-2023, 02:17 PM | #10 |
Funny, I've never thought of needing a tool for these. I use my vice and two sockets. one just smaller than the hole the bushing is in and one that is just a tad larger than the bushing, to push the bushing into. I have a set of 3/4 drive sockets that provide the receiving end. Just sqeeze them back into place with the vice.
The "ace" mechanic |
07-31-2023, 02:30 PM | #11 |
A good way to remove bushings and bearings is to heat the inside on one side only until red hot but do not melt. Wait until it cools and usably it can be slipped out with your fingers. When you heat something red hot in one place only, inside a diameter it squeezes the metal together at that point but when it cools off it has shrunk that diameter too the point it is a smaller diameter.
07-31-2023, 03:50 PM | #12 |
I know that there are a lot of ways to skin a cat, but at $13 for the tool made to do the job seems to be kinda a no brainer
07-31-2023, 04:29 PM | #13 |
Phil, you are absolutely correct ...however that stupid Shipping & Handling make that $13 quickly go to $33!!
07-31-2023, 04:30 PM | #14 | ||
Great tip!! I/We have used a welder to remove races from differentials and hubs before, but never thought about trying that on bushings. Thanx!! |
07-31-2023, 05:25 PM | #15 |
Only if it works… I’ve purchased “special” tools that didn’t work. Once I purchased a bushing driver just like the one shown and when it turned up it was made from aluminum - and not hardened. Mushroomed into something useless.
07-31-2023, 06:07 PM | #16 |
07-31-2023, 06:21 PM | #17 |
Just as an aside, that’s why I like to deal with Burts - they charge only the actual shipping cost.
07-31-2023, 09:45 PM | #18 | |
I'm part of the only ever generation with an analogue childhood and a digital adulthood. Last edited by Synchro909; 08-01-2023 at 05:42 PM. |
08-01-2023, 10:25 AM | #19 | ||
08-02-2023, 08:29 PM | #20 |
Uesd my old clutch pilot bearing puller - https://www.grainger.com/product/48U...E&gclsrc=aw.ds
Squeeze them back in with a big C clamp |
