08-16-2016, 02:38 PM | #1 |
6volt fuel pump
What is the best 6 Volt Electric fuel pump to use for a stock flathead? I do not plan on going through the stock pump. Thank you guys!
08-16-2016, 02:56 PM | #2 |
Re: 6volt fuel pump
If you do a search on this forum (6 volt fuel pump) you will find many posts on this subject
08-16-2016, 03:15 PM | #3 |
Re: 6volt fuel pump
I am very pleased with the Airtex E-8902 I installed on my '41. Four years and no problems. Mine is activated by a switch under the dash and is used as needed.
They are available from Advance,NAPA,OReilly and others. About $45.00. |
08-16-2016, 05:25 PM | #4 |
Re: 6volt fuel pump
08-16-2016, 05:33 PM | #5 |
Re: 6volt fuel pump
I cannot remember the part number, it is an Airtex and is 6volt from rockauto.com installed in 2009
Thank God this is only a hobby! |
08-16-2016, 06:25 PM | #6 |
Re: 6volt fuel pump
If it aint broke, don't fix it! |
08-16-2016, 08:32 PM | #7 |
Re: 6volt fuel pump
funrunr it is the one described above and seconded by the others.
08-16-2016, 08:57 PM | #8 |
Re: 6volt fuel pump
The Airtex has boiled to the top in most of the previous threads on this subject. The July/August V-8 Times has an article written by Randy Rundle describing a gear type pump (available 6 or 12 volt), with stainless steel gears similar to a positive displacement oil pump, that he sells through his Fifth Avenue Auto Parts store. He claims no need for regulator when using 6 volt pump (2-5# output). Worth checking out. Has anyone tried one of these pumps?
08-16-2016, 09:31 PM | #9 |
Re: 6volt fuel pump
Thank you everyone !
