05-15-2016, 07:40 PM | #1 |
1933 transmission cover bolts?
I have removed 4 of these transmission cover slotted bolts, with 3 to go. I suppose they originally had some type of washer to go with the bolt. Where can I can a new set of these slotted bolts and the proper washers. I bet DavidG has a pix of the cover with proper bolt/washers, thanks in advance.
05-16-2016, 07:24 AM | #2 |
Re: 1933 transmission cover bolts?
Do you call Roy Nacewicz
05-16-2016, 01:49 PM | #3 |
If you mean the top cover (shift lever housing), there are six of them and they were 5/16-18 x 7/8" hex head bolts, not slotted, used with 5/16" split lock washers. I do not recall any place on either a four-cylinder or V-8 transmission that uses seven bolts. Please clarify.
05-16-2016, 01:51 PM | #4 |
There are only two slotted bolts on the transmission inspection cover for the clutch pressure plate area. The top shift cover is held on with 6 hex head bolts with lock washers only. The bolts have a thick head and a section under the head without threads (the bolt threads do not extend all the way to the bolt head) Roy has nearly all the hardware you need.
05-16-2016, 05:07 PM | #5 |
The transmission cover under the floor mat, covers the top of the shift tower, it is cutout for the chatter rods, has 7 slotted heavy bolts, 3 on each side, 1 at the back over the torque tube bell, mine are buggered up and I am missing some type of washer.
05-16-2016, 05:59 PM | #6 |
05-16-2016, 06:01 PM | #7 |
Yep, need those 7 slotted bolts and some type of washer, NOS preferred, NO china, junktique
05-16-2016, 06:01 PM | #8 |
The screws for the transmission floor cover, yes they are slotted and Roy has them. They come with the special cup washers. They do not have a lock washer. They are also used in other various places in the floor and screw into caged nuts that are welded to the frame. You can reach Roy at 734-654-9450 or www.fordbolts.com
05-16-2016, 06:07 PM | #9 |
One suggestion I would add is to clean out the nuts really well before installing the new bolt/screws. I would use a thread chaser or a tap to clean them out. I would also put something on the threads such as never-seize.
05-16-2016, 06:59 PM | #10 |
Nowhere in any Ford hardware catalogue can you find any reference to flat-head slotted screws as "bolts". What's heavy about those screws as they are only have a 1/4" thread? A little accuracy in posing the question will go a long way to getting good answers.
05-17-2016, 10:04 AM | #11 |
They are the same as the center floor, door hinges, and a few other places. different lengths but all are 5/16x24 thread with countersunk slot head with countersunk washers. Call Roy and just buy them, you will be glad you did, nice bolts.
05-17-2016, 03:43 PM | #12 |
Roy advises that they are unique in that they have #12 heads, which is two sizes smaller than a normal 5/16 screw head. That makes sense given that they are to be used with countersunk washers. In other words, not likely to be encountered at a hardware store.
05-17-2016, 04:09 PM | #13 |
Definitely not normal hardware store stuff .
05-17-2016, 06:17 PM | #14 |
Roy sells the correct ones.. PS..... they are the same as door hinge screws on some Early V8's. Same with the cupped washer.
s-l500 (1).jpg |
05-17-2016, 07:38 PM | #15 |
I ordered a set of these today, talked with Roy himself, heck of a nice guy.
