Old 09-30-2021, 01:01 PM   #21
flatjack9
flatjack9's Avatar
Default Re: L100 Camshaft using 59ab valves
I've got a Winfield SU-1A cam in my engine with hollow adjustables and 55 lb seat pressure. Back in my younger days, I would spin the engine to 5000 rpm. No perceived problems, but I didn't spend much time at 5000 rpm either.
flatjack9 is online now   Reply With Quote
Old 10-03-2021, 02:31 PM   #22
Roger/Sacramento
Roger/Sacramento's Avatar
For whatever it is worth here is my experience with an L100 in my 276 with 3- 97's. I like the acceleration thru the gears, but if the RPM's go below 2000 the engine will buck. I don't go over 4000 because I like to be able to drive home. A T5 manual shifter is a nice tranny for this combination.
KIM KARDASHIAN ISN'T FLAT, BUT MY MOTOR IS.....
http://s818.photobucket.com/home/roglehr/index
Roger/Sacramento is offline   Reply With Quote
Old 06-18-2022, 07:12 PM   #23
Fairlane500
Fairlane500's Avatar
What rear gears are you running and tyre profile?
Life is not a dress rehearsal...
Fairlane500 is offline   Reply With Quote
