03-14-2020, 07:52 PM | #21 |
Re: 130B Deluxe Delivery For Sale On Ebay
The gas tank for an indented firewall does not have a gas line that runs through the passenger compartment to the firewall. The indented firewall gas tank outlet matches the hole on the firewall and the gas shut off valve screws into the gas tank on the engine side of the firewall.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
03-14-2020, 08:00 PM | #22 |
I used photo shop and lightened the photo of the under tank connection. There may not be a valve on the gas line but it is a non indented fire wall gas tank.
03-15-2020, 01:03 AM | #23 | |
(that would be an easy $10000 profit!) |
03-15-2020, 05:35 AM | #24 |
No one has mentioned the non-side bowl carburetor.
Indented firewall car should have side bowl carburetor. |
03-15-2020, 05:51 AM | #25 |
The steering column support bracket I believe should be mounted to the dash not the fuel tank
03-15-2020, 10:31 AM | #26 |
03-15-2020, 11:48 AM | #27 | |
I haven't had any experience with an indented firewall A but I learned something new today...Thanks... TOB |
03-15-2020, 12:23 PM | #28 | |
03-15-2020, 12:50 PM | #29 |
Probably. I wish it was restored to originality as it was supposedly owned by a bakery (see last photo).
"The more things change, the more they stay the same." |
03-15-2020, 01:05 PM | #30 | |
read post # 22 I used photo shop and lightened the photo of the under tank connection. There may not be a valve on the gas line but it is a non indented fire wall gas tank.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? Last edited by 160B; 03-16-2020 at 10:32 AM. |
03-18-2020, 03:05 AM | #31 |
wonder how well it runs since a spark plug wire is disconnected.
03-18-2020, 01:44 PM | #32 |
Good Morning...I wonder if this 'A' was built out of parts and not by Henry? Ernie in Arizona
03-20-2020, 09:07 AM | #33 |
Ended with no bids. Poor fellow didn't make his $10,000 quick profit!!!!!!!!
AL in NY |
03-20-2020, 03:17 PM | #34 |
It’s back on eBay but this time at $39,900 with “best offer”.
