02-08-2020, 09:21 PM | #1 |
33 rear bearings
Removed rear bearings from hub and somebody before me must have removed them in a somewhat aggressive manner. The cage has been damaged possible when driving out the seals, they were then replaced with the damaged side to the bottom of the hub.They are ford bearings should I try & grind off the damage ?
02-08-2020, 09:25 PM | #2 |
Re: 33 rear bearings
By the way I used Lawrie's trick in removing seal & bearing. It only worked for one side. The other side was loctited in.
02-09-2020, 12:52 AM | #3 |
02-09-2020, 02:50 AM | #4 | |
Kpar |
02-09-2020, 03:53 AM | #5 |
Has the bearing gone through the case hardening on the inside of the hub?
02-09-2020, 04:20 AM | #6 |
02-09-2020, 04:26 AM | #7 |
It´s more about if they managed to twist the roller cage then if there is a few marks on it.
If the cage is deformed or twisted the rollers will move sideways causing axialforce and increased wear on the bearing surfaces. Think pitch of a nut/bolt |
