Old 06-11-2018, 10:17 AM   #1
burner31
burner31's Avatar
Default Which filament is low beam?
Which filament is which on a 6V bulb?
Keith
Shawnee OK
'31 SW 160-B
Old 06-11-2018, 10:33 AM   #2
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Which filament is low beam?
I've never seen filaments like that before. I'd guess the straight one is parking, as it looks thinner.
Actually that looks like an early parking/driving bulb. Since both filaments are in the center it won't have high/low beam aim.
Old 06-11-2018, 10:48 AM   #3
Bob C
I think that bulb is the new replacement 50/32 cp bulb with the wrong
shape filament. The picture shows what they should look like.
Bob
Bob C is online now   Reply With Quote
Old 06-11-2018, 10:55 AM   #4
Merc Cruzer
Merc Cruzer's Avatar
I would turn on the lights and see what filament light up then push on the high beam switch and see if the other filament light up. Wiring diagrams are great but many times observation is more accurate.
Merc Cruzer is offline   Reply With Quote
Old 06-11-2018, 12:54 PM   #5
Badpuppy
From what I gather, the shorter stems hold the brighter filament, which should be placed lower than the other. Frankly, I can't tell any difference in brightness.
Your #1188 is a 50/32 bulb, I dunno what Bob C has.
A problem I found in my car was one of the bulbs' filaments weren't aligned with the contacts and had a 'dip to the left' when dimmed. The other bulb was an original Gross branded 21/21 cp, with ridged edge around the front of the glass. Still works.
Old 06-11-2018, 08:12 PM   #6
Tom Wesenberg
It was an optical illusion, and now I see one filament is below the other. The filament on center should be HI beam and the filament placed above center should be LOW beam.
Old 06-11-2018, 09:13 PM   #7
redmodelt
redmodelt's Avatar
It is not how bright the lights are but how the beam is aimed, the shape of the reflectors and lens.
Old 06-11-2018, 11:52 PM   #8
Mike V. Florida
Mike V. Florida's Avatar
As Tom said, "The filament on center should be HI beam and the filament placed above center should be LOW beam."
redmodelt has an often overlooked and before now new impossible to get right comment.
Ever have one of those focusable flashlights? The bulb output is the same but the light is more useful when focused even seems brighter. The correctly shaped reflectors are available that are also aluminum coated so as to be as close to polished silver without worry about tarnish.
Old 06-12-2018, 01:35 AM   #9
burner31
burner31's Avatar
Thank you Tom, thank you Mike...and thank you all
Keith
Shawnee OK
'31 SW 160-B
Old 06-12-2018, 08:31 AM   #10
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
I remember Tom saying, "Look at them with a welding helmet, when studying the filaments, when they're TURNED ON"!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 06-12-2018, 10:03 AM   #11
Badpuppy
Here's the reflectors Mike V mentioned -
https://www.brattons.com/newly-re-to...eflectors.html
The instructions tell how to install the bulbs...(Could I have been wrong????)
Old 06-12-2018, 06:05 PM   #12
quickchange
quickchange's Avatar
Down under we have too put them up the other way?
quickchange is offline   Reply With Quote
Old 06-13-2018, 09:56 AM   #13
Badpuppy
Might as well. Everything there swirls the wrong way anyhow.
Old 06-13-2018, 09:22 PM   #14
updraught
updraught's Avatar
https://www.nytimes.com/1975/01/25/a...de-of-the.html
If you changed to RHD your world would be a lot calmer.
updraught is offline   Reply With Quote
Old 06-14-2018, 01:51 AM   #15
burner31
burner31's Avatar
I was thinking of going to Australia once...until I seen what panda's REALLY look like
File Type: jpg 028f2030-54a3-4e0c-813b-ff836f00de8a.jpg (36.5 KB, 83 views)
Keith
Shawnee OK
'31 SW 160-B
Old 06-14-2018, 08:55 AM   #16
Badpuppy
I remember that article. Claimed by a bunch of California chuckleheads.
Keith: updraught's avatar is what an Australian panda REALLY looks like.
And boy, are we off-topic. Have you figured out yet which filament is low beam? (I haven't.)
Old 06-14-2018, 09:29 AM   #17
burner31
burner31's Avatar
Yes, the small filament is low beam
Now to get them focused
Keith
Shawnee OK
'31 SW 160-B
Old 06-14-2018, 11:42 AM   #18
Badpuppy
Thanks. I'll go swap mine now.
Old 06-14-2018, 11:28 PM   #19
updraught
updraught's Avatar
https://www.youtube.com/watch?v=OhjopjpqxAc
Beats milking cows
Old 07-14-2018, 09:28 AM   #20
Badpuppy
Well, Bratton's instructions are wrong. Here's how filaments work:
Longer filament = higher resistance = lower current = less light (dim)
Shorter filament = lower resistance = higher current = more light (bright)
The filaments are equidistant (1/16") from the center plane that intersects the base contacts, so the original headlight reflector opening is elevated to compensate for this, causing the brighter filament to be adjusted along the parabolic axis.
http://www.fordgarage.com/pages/Aheadlampreflectors.htm
So install the bulbs with the longer filament on top and make sure it's the one that illuminates with the light switch in dim position. If not, either spin your (repro) reflector 180 degrees or swap wires at the conduit socket.
Back to bulb spinning.
