01-26-2015, 01:56 PM | #1 |
Machine Shop for Flatheads near Charleston, WV
Im looking for a reputable machine shop that has experience with flathead machine work. I'm rebuilding a 59 ab & an 8ba. Does someone have an experience or resource their willing to share? 2-3 hours in any direction is OK. All feed back is appreciated.
01-26-2015, 10:50 PM | #2 |
Re: Machine Shop for Flatheads near Charleston, WV
Check out this machine shop. I have heard good comments about them but have never used their services.
http://givensmachineshop.com/
Son, you will never blow an engine up in high gear. |
01-27-2015, 02:39 PM | #3 |
Hi "d", whichever shop you choose I can give you a tip or two about a few questions you should ask before making a final decision. I would have no problem if any of my own customer's inquired about them here.
1-Are they willing to remove the crank plugs for cleaning and tapping and drilling for pipe plugs? 2-Are they able to install valve seats if required? 3-Are they able to balance the rotating ass'y? 4-Are they able to measure all clearances precisely using bore gauges? This includes cam brg's, rod brg's, and main brg clearances? (Ability to grind the crank goes without saying) 5-Do they use a deck-mounted boring bar or bore from the mains (preferred)? Do they use a block-plate for finish honing? 6-Are they able to do any and all rod work, from resizing to installing new pin bushings? 7-Are they familiar with machining for the 95% filtration system? (Even if you don't choose to have it done) Not that you will need all these procedures, but it's nice to know how familiar they are with the "Flatties". On a side note I would want to use bronze-lined guides/stainless valves without fail AND also some "moly" piston rings for quick seating. (Add) Make certain the castings (blocks) get pressure-tested, and the lifter bores get drilled if using adjustable valve train, BOTH these are mandatory here. Thanks, Gary in N.Y. P.S. I would also ask if they could pin the heads to the block like the SBC's, makes for much longer head gasket life! This isn't mandatory, just a little extra "insurance".
http://www.stromberg-bulletin.com/me...berg-equipped/ Last edited by GOSFAST; 01-27-2015 at 02:43 PM. Reason: Add info |
01-27-2015, 07:27 PM | #4 |
Great advice Gary
01-27-2015, 07:57 PM | #5 |
Another vote for Givens Machine Shop!
01-27-2015, 11:28 PM | #6 |
Take care, B&S |
