06-22-2021, 05:29 PM | #1 |
Wiring insulation burn-through
I, after many years with 40's flatheads learned that wires; sparkplug, temp sender crossover, etc. that rest on the intake manifold can and do burn through in the area of the carb. Any of you experience this and do you know a source for conduit that is fabric or other not shiny material to cover those wires where they burn through?
06-22-2021, 05:49 PM | #2 |
Re: Wiring insulation burn-through
06-22-2021, 05:55 PM | #3 |
Suggest you replace with high temperature wire (Like used in stoves) You can get it in black with the cloth like outer cover.
06-23-2021, 10:46 AM | #4 |
I believe all our usual vendors sell cloth covering to make up wire looms. It's intended to look like original cloth covering. I would think your cloth covered wires would be protected if in a second cloth loom, and the appearance would be near-correct.
06-23-2021, 11:02 AM | #5 |
Contact Tyre Harris
06-24-2021, 04:26 PM | #6 |
