04-29-2021, 01:48 PM | #1 |
1927 Model T Brakes
Trying to learn about the braking system on a T. Did the '26 & '27 have functioning rear brakes? Or were the only brakes actually used while driving just the bands in the tranny?
04-29-2021, 02:54 PM | #2 |
Re: 1927 Model T Brakes
The rear brakes are actually a parking brake as they are cast iron band w/ no shoes. Only driving brakes are the band in the transmission.
04-29-2021, 10:24 PM | #3 |
The "Improved" Ford ('26 - '27) actually had a lined rear brake band - earlier were cast iron.
04-30-2021, 09:48 PM | #4 |
05-01-2021, 07:10 AM | #5 |
The inside brake shoe or "band" as I think you are calling it in 26/7 was lined. There is a external accessory brake outfit called Rocky Mountain brakes that has a external contracting band on the outside of the brake drum.
05-04-2021, 06:50 PM | #6 |
05-20-2021, 11:04 AM | #7 |
The 26-27 T park brakes are much larger than the earlier park brake. There is a outfit ( Model T Ranch ) that makes a equalizer to connect the park brake to the brake paddle so they can be used as a service brake. There are mixed revews on how well they work.
05-20-2021, 01:51 PM | #8 |
Biggest draw back using the 26/27 as service brakes, they just float inside the drum, not anchored down. Yes people do use them as parking/service brakes. As bad as Rocky Mtn are reported to be, that at least do have one anchor point.
I know the voices aren't real but damn they have some good ideas! |
