Go Back   The Ford Barn > The Archives > Model-A
Old 01-01-1970, 12:00 AM   #1
Guest
Posts: n/a
Default Welding Front Brake Roller Tracks
Is it acceptable to build up a degraded roller track with a small oxy/acetelene torch or will it make the track to brittle?
<table><tr><td><font face="arial">
Old 01-01-1970, 12:00 AM   #2
Guest
Posts: n/a
Default Re: Welding Front Brake Roller Tracks
Yes, some of the books suggest that you do it that way.I did mine with no problems. I used good sharp files to dress them back down. Make you have good pins and rollers when you put it back together.---bert
Old 01-01-1970, 12:00 AM   #3
Guest
Posts: n/a
Default Different distances from Rivet
The front and back have different distances from rivet to the flat spot. I just don't have that information handy right now.
Old 01-01-1970, 12:00 AM   #4
Guest
Posts: n/a
Default Re: Different distances from Rivet
I've never paid attention to the distance relative to rivets. However, both front and rears were located 4.620" from the plate center line.
