06-30-2012, 10:26 PM | #1 |
Holes in back of transmission case...
I just noticed something and I should know the answer to but do not know. I have several transmissions and all but two of them have the four holes that accept the throw-out bearing assembly tube as they should.
What are the two transmissions which do not have the four holes used for? Just how was the throw-out bearing assembly tube attached? They are the later transmissions with the thick bearing flanges on each end. Pluck |
06-30-2012, 11:11 PM | #2 |
Re: Holes in back of transmission case...
The ones without the four holes in front were on the early cars with a multi-disk clutch. They did not use a front bearing retainer that the later throw-out bearing slid on. The early throw out bearing mounted on the clutch pack and rotated with it. The grease fitting was actually inserted into the throw-out bearing itself.
Tom Endy |
07-01-2012, 08:28 AM | #3 |
i have some photos on my site
07-01-2012, 12:10 PM | #4 |
Pluck |
