03-11-2020, 02:56 PM | #1 |
Some Bad habits !!!!
Over the years you could tell a lot about a guys skills as a mechanic based on what lube he used. I have torn down gasoline engines with white lube in them so deep the engine was locked up !!! Seen them blown up using STP straight
( its a concentrate know) only works when mixed with oil?? I took this crab in as a customer had rebuilt , just for testing etc , dont actually know if he ever tryed running it or not ( doesnt matter) put it in the distributor machine and Terry even commented as to how nice it looked !!! Clean and well done , but when i fired the machne up two things happened , 1=it has no advance and two it blew the circuit breaker on my Allen tester . ( kinda rare) ... Further showed a very dry leather vac brake so i removed it and it still didnt have any advance . On the bench and apart (even had a screw in place of condensor screw using a ton of locktite , had trouble getting it out ) And there it was the dreaded old cold white lube !!!!! Ya just cant do that !!!!!! I found a can of spray lube that works very well and prevents rust at the same time . Stay tuned we will clean it up and retest !!!!! The vacuum brake should be lubed as per picture , the lube on the leather is good and the lube on the piston prevents the wife ( had this a couple times) saying honey i hear a little bitty squeal in the engine ,there is nothing worse than a kittle bitty squeal that you ( ole deaf guy) cant hear and the wife can ????rbgt Last edited by BUBBAS IGNITION; 03-11-2020 at 03:28 PM. |
03-11-2020, 03:31 PM | #2 |
Re: Some Bad habits !!!!
Lubriplate 105 perchance? Heard of it being used in steering boxes.
I dig coal, which provides motivation for EVs. |
03-11-2020, 05:29 PM | #3 |
Yep it could very well be lubriplate !!!!
03-11-2020, 07:39 PM | #4 |
I believe lubriplate is a soap based lube.
Bruce
Works good Lasts long time |
03-11-2020, 10:08 PM | #5 |
My dad used lubriplate on everything and it always dried out and turned hard. I have never used it on anything.
03-16-2020, 02:24 PM | #6 |
03-16-2020, 02:27 PM | #7 |
