Old 08-04-2019, 01:51 PM   #1
Sparta
Default Replacing fuel shutoff valve, does tank need to be empty?
Hey guys! I’m replacing my fuel shutoff on my 31 model a. Does the gas tank have to be empty to do so? I see it threads right off, maybe just sneak a bolt onto the gas tank to stop it from pouring out?
Thanks!!
1931 Ford Model A Tudor
Complete stock rebuild
Disregarding the constabulary since 1931
Sparta is offline   Reply With Quote
Old 08-04-2019, 01:54 PM   #2
Aretino
Aretino's Avatar
Default Re: Replacing fuel shutoff valve, does tank need to be empty?
I just drained my tank into gas can by attaching hose to firewall fitting. Eliminates gas spills on the interior.
Aretino is offline   Reply With Quote
Old 08-04-2019, 02:28 PM   #3
wmws
Yes drain it completely. Even then have a pan under it to catch the little bit remaining. You do not want gas on your floor mat. Do not screw a bolt into the drain hole. Wrong thread.
wmws is offline   Reply With Quote
Old 08-04-2019, 02:30 PM   #4
Kurt in NJ
Kurt in NJ's Avatar
If it had a stand pipe --- pencil filter added there will be trapped gas , could be more than a gallon
Old 08-04-2019, 02:41 PM   #5
WHN
I drain tank and than put an old bath towel under it before replacing valve. Enjoy.
WHN is online now   Reply With Quote
Old 08-04-2019, 05:23 PM   #6
Mulletwagon
Mulletwagon's Avatar
Expect about a cup of fuel to drain out when the valve is unthreaded. Use some teflon tape on the new valve threads.
Mulletwagon is offline   Reply With Quote
Old 08-04-2019, 06:30 PM   #7
JoeCB
JoeCB's Avatar
Be careful with steel tools around the steel tank, no bumping or banging around... sparks and leaking gasoline- not a good thing!
Joe B
JoeCB is offline   Reply With Quote
Old 08-04-2019, 09:41 PM   #8
Jeff/Illinois
Jeff/Illinois's Avatar
Originally Posted by Mulletwagon View Post
........................ Use some teflon tape on the new valve threads.
May want to re-think that, teflon tape isn't good around gasoline applications.
I'd use a bit of Permatex non-hardening sealer made for gasoline fittings
Old 08-04-2019, 10:07 PM   #9
daren007
You don't have to drain it...But I would. There are products specifically made for sealing fuel, "Fuel Lube" is one.
daren007 is offline   Reply With Quote
Old 08-04-2019, 10:40 PM   #10
Bill G
Bill G's Avatar
I drained mine by removing the fitting from the carb and extending it with a rubber hose to drain into a 5-gallon gas can. That will save you a lot of grief of you don't drain it. as stated by others, you will still get some when you actually take the valve off, so I guess I am just saying what everyone else has.
Old 08-05-2019, 09:34 AM   #11
katy
katy's Avatar
After you drain as much gas as you can get out of it, block up the RH side of the car about 4" so any remaining gas will shift away from the shutoff valve, before removing the valve.
Old 08-05-2019, 04:54 PM   #12
Forddan
I used yellow gasoline resistant teflon tape. So far so good.
The standard white teflon tape will melt in a few hours
Forddan is offline   Reply With Quote
Old 08-05-2019, 05:54 PM   #13
1931 flamingo
1931 flamingo's Avatar
DISCONNECT the battery first.................................FWIW........ JMO.
Paul in CT
