Old 05-23-2018, 09:34 AM   #1
Bud Man
Bud Man's Avatar
Default Grease Gun Fitting
Recently purchased a old style grease fitting tip from Snyders, and have run into a problem. Seems my gun (China) is threaded to a metric M10-1.0 while the tip is UNF at 3/8-24. Close, but no ceegar. Does anyone know of a decent hand-operated grease gun that is threaded to fit the 3/8-24 UNF size tip?
Bud Man is offline   Reply With Quote
Old 05-23-2018, 09:44 AM   #2
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Default Re: Grease Gun Fitting
I use a mixture of CHASSIS Grease & GEAR oil in steering boxes.
Bill Slick
"THE ASSISTANT GURU OF STUFF"
Old 05-23-2018, 11:41 AM   #3
Ruth
Really? I have several different 'tips' from needle to the "old style grease fitting tip from Snyders" and they all fit both of my grease guns from HF. I just assumed it was a standard size.
Bill Slick
Not sure what that has to do with the grease gun tip fitting his grease gun...
Old 05-23-2018, 01:00 PM   #4
SeaSlugs
SeaSlugs's Avatar
can you find a modern grease fitting to screw into the adapter that you can snap onto the standard end you have on your gun?
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 05-24-2018, 08:31 AM   #5
katy
katy's Avatar
Are you sure that it's not 1/8-27 NPT? That's what most grease guns are.
Old 05-24-2018, 10:01 PM   #6
Bud Man
Bud Man's Avatar
Positive it's a M10-1.0 Definitely not NPT.
