Old 04-26-2018, 07:05 AM   #1
rocket1
Default gearshift lever ball repair
the ball on the end of my 29ccpu shift lever is badly worn,anybody have experience welding it up and grinding it round? I'm going to attempt it,pointers would be helpful,thanks.
rocket1 is offline   Reply With Quote
Old 04-26-2018, 07:35 AM   #2
Terry, NJ
Terry, NJ's Avatar
Default Re: gearshift lever ball repair
Yes I did! I MIGged it, then I forged it round it on my anvil and worked it on my freehand grinder. Then I finished it off with a file. I used a shifting fork as gauge. You must not only fit it to the slot, but allow it to make the "Throw" to get into the various gears. Go to my albums, "My A" and there are pics in there.
Terry
Terry, NJ is offline   Reply With Quote
Old 04-26-2018, 09:07 AM   #3
katy
katy's Avatar
I did the same as Terry except no pictures.
Old 04-26-2018, 10:47 AM   #4
Russ/40
Russ/40's Avatar
I gas welded mine. You can control the flow and make a pretty round ball that requires little shaping afterwards.
Russ/40 is offline   Reply With Quote
Old 04-26-2018, 02:55 PM   #5
Keith True
Keith True's Avatar
Just use a washer with the same size hole as the OD of the ball for a guage.Weld,grind,file and fit until the ball is the same size as the hole in the washer.
Keith True is offline   Reply With Quote
Old 04-26-2018, 05:01 PM   #6
larrys40
Keith,
I like that idea! Excellent. It should be 1/2 inch if I remember. I use to braze them up and shape them round
Larry shepard
larrys40 is offline   Reply With Quote
Old 04-26-2018, 05:52 PM   #7
Big hammer
I remember .490 but lets not split hairs :-) I need all I have!
get a bigger hammer tap done
Old 04-27-2018, 10:38 AM   #8
rocket1
I understand Craig Riker from the Toledo Ohio area sells reconditioned shift levers,anybody have the contact info on him,thanks in advance.
