Old 07-12-2021, 07:54 AM   #21
tub1
tub1's Avatar
Default Re: Generator and fan setup 59 AB
think if it was my car and I didn't like the look of the alternator and if it works good every think is 12 volt why monkey around making thins less efficient and cost , just make a cover for the alternator that makes it look like a generator not that difficult I was going to do this to the alternator I fitted to my 39 but I have so much fun driving it with bright lights etc with the hood shut ive forgot how ugly the alternator looks
tub1 is offline   Reply With Quote
Old 07-12-2021, 10:04 AM   #22
rottenron36
rottenron36's Avatar
I have a 59 AB in my 36 pickup and it fits perfectly. Don't know about he difference between 34-36.
rottenron36 is offline   Reply With Quote
Old 07-12-2021, 10:19 AM   #23
V8COOPMAN
V8COOPMAN's Avatar
And yes....a 59-AB ENGINE will fit perfectly, as ALL of the BASIC flatheads from '32 thru '53 are configured the same. The questionable item here is the FAN. I would love to see what kind of fan you have on your '36 PICK-UP. It should be noted that the pick-ups of the years we are discussing here have MORE room for fans as the pick-up radiators do NOT lean back as drastically as on the passenger cars. Could you possibly post a picture of your fan? It should be noted here that a 59-AB fan assembly will NOT fit in a '36 passenger car with stock radiator. Ask me how I know! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 07-12-2021, 12:46 PM   #24
HD
The correct generator mount is stamped 21A, used from 1942-1948, it has the 2 holes to slide the fan up and down to adjust the belt, used on the generators with a 4 1/2 " case, will not fit the early 3 brush generators with a 4 " case
HD is offline   Reply With Quote
Old 07-12-2021, 01:36 PM   #25
cas3
I think the OP wants an all 34 gennie and fan if I have followed this correctly
Old 07-12-2021, 01:46 PM   #26
cas3
Here's my 59ab in a 34 with Whitney converted 34 gennie, complete with fake cutout, and 34 fan and radiator. 12v neg g, (you can get 6v if you wish) with 12 volt coil rewound by skip. Who would know its not a generator if i didn't tell you? sorry, not a good pic, just one I had in stock
Old 07-12-2021, 04:26 PM   #27
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Cas3, now I like that? Where did you have it done and the cost?
Tim Carlig
dean333 is offline   Reply With Quote
Old 07-12-2021, 04:57 PM   #28
cas3
Done here https://ejwhitneyco.com/automotive.html
Old 07-13-2021, 08:47 AM   #29
rottenron36
My fan set up in my 36 pickup is stock 59 AB and the same as the one pictured in the second post. So pickups must have more room for the fan. Ron
Old 07-13-2021, 08:54 AM   #30
38bill
38bill's Avatar
Its the stock 59A fan assembly that is the problem when used on a '34 car not the generator mounted fan in a car. Apparently the car radiators tip back so there's less room than the trucks.
38bill is offline   Reply With Quote
Old 07-13-2021, 10:22 AM   #31
V8COOPMAN
V8COOPMAN's Avatar
Bill is correct! This '36 pick-up with a 59-AB shows how much more room is available with it's radiator that sits so much more "straight-up" than a '34 or '36 passenger car radiator. DD
T5 W/TORQUE TUBE
