07-29-2012, 08:10 PM | #1 |
Universal Joint Connection
When I install my motor and transmission I will be doing it together. My question is about the "Inner Cover" around the universal joint as illustrated in Les Andrews book. This cover has two holes in it and I was wondering if these holes are located side to side or top to bottom?
Thanks for your time. Joe Grobleski |
07-29-2012, 09:22 PM | #2 |
Re: Universal Joint Connection
No one knows the answer to the above question?
Thanks for your time. Joe grobleski |
07-29-2012, 09:41 PM | #3 |
Position it so the holes are at 3 and 9
_________________________________________ 1931 Ford Model A Tudor 1930 Ford Model A Deluxe Roadster 1930 Ford Original Rolling Chassis- Restoring |
07-29-2012, 09:53 PM | #4 |
I didn't know which way the holes should be when I assembled my u-joint. I ended up putting the holes at 3 and 9 o'clock as suggested above. Don/WI
07-29-2012, 10:16 PM | #5 |
Thanks to bogdonj and Don/WI for your info.
Joe Grobleski |
07-29-2012, 10:48 PM | #6 |
