07-10-2017, 08:56 PM | #1 |
60 mile per hour all day long?perhaps..
Got an engine from a friend for doing a coupla hours of welding on his '58 Apache 3100 dumping pickup (original aftermarket dual cylinder hoist and pto drive,its very cool).it looked like it had been built not that long ago and he said he pulled it from a car for another guy...said it blew a head gasket..I figured i couldnt go wrong,Id have done the welding for free.Tore it down tonight,was stoked to see the fresh valves
and gleefully pulled the pan...first thing I saw was the glyptal I was downright joyful Then I noticed the center main had a cauliflower ear of babbit,and knew it was all too good to be true.. I wonder if this engine did a 60 mph all day....oh well I want to run inserts and a counterbalanced crank anyway.I wonder what can be saved,I was thinking the valve job could be lapped back in..or should I just start fresh? |
07-10-2017, 10:09 PM | #2 |
Re: 60 mile per hour all day long?perhaps..
Now is the time to check everything, but the valves look like new, and I wouldn't grind them unless something is wrong with them. Just turn the cam gear around and check the seating area of each valve when it's open.
07-10-2017, 10:55 PM | #3 |
I agree,the next move is to completely disassemble,measure and magnaflux..If it checks out I'll get started building a touring engine.There's a gentleman in Turlock who has a good reputation for machine work,Ill employ his services if available.I like doing my own assembly work,no one spends the time lapping polishing and 'blueprinting' like an owner can,the labor is free..Got a nice 1/10th gram scale too so I can static balance a bit too.One question I do have is about counterbalanced crankshafts,everyone seems to recommend lightening the flywheel at the same time...not so sure I want to do that,seems to me the heavier flywheel would work in combination with the counterbalance crank and allow a smoother running engine.Sacrifice a little 'spool' up speed for more dampening?
07-11-2017, 01:03 AM | #4 |
Always an unending conversation about lightened flywheels; however, Ford lightened the B flywheel a bit when he installed the counterbalanced B crank; and many old vintage machinists in our rural area told me in the early 1940's that they were often asked to lighten Model A flywheels for customers.
Engine re-builder Mr. Ron Kelley always recommends lighter Model A flywheels when used with his counterbalanced crank ..... he did mine as such .... no complaints even in hill country. Seems evaluating different, varying choices of others is done every day with all things ..... I got used to it years ago. LOL Last edited by H. L. Chauvin; 07-11-2017 at 01:05 AM. Reason: typo |
07-11-2017, 06:01 AM | #5 |
No, Babbitt does not just fail from running 60 MPH all day long.
Babbitt fails because it was not done right. Babbitt seems simple, just pour it and bore it. No, there are many rules you must follow or it will come apart. That Babbitt was not bonded to the cap. Looks like it was tinned, but the babbitt did not get well adhered to the tinning. Contrary to many peoples opinions. A well balanced system and proper babbitt take a beating and keep on running. It has been our experience that babbitt is just not done right more often then not. With exception to a few shops that know the science of pouring babbitt we have found many guys are just clueless on how to pour babbitt in such a way as to not introduce fail points. By experimentation we found many ways to screw up babbitt. In talking to various guys doing babbitt we found they were doing things that would lead to babbitt failures like what you see in the above picture. In the end, if babbitt fails it is because it was done wrong in the first place. I guess I have to add in, you can make it worse by improper balance or running in such a way to cause pre-detonation. |
07-11-2017, 06:05 AM | #6 | |
Bearings only care about oil and forces. Counter balancing is not the critical issue with the A crank (do not get me wrong it can improve it). The critical issue is being anal about machining and balance. |
07-11-2017, 07:49 AM | #7 |
If the flywheel stores energy and dampens pulse..wouldn't the dampening effect of counterbalancing be aided by more flywheel mass then less?
The tinning on the bearing cap is good,it appears the babbit itself failed. Im not trained in poured babbit bearing failure analysis. Usually when an insert bearing fails structurally like this there are telltale heat indications..on this one,the crankshaft looks perfect,however.there is glazing and evidence of light vertical scoring of the cylinder walls from piston heat distortion,that's where Im jokingly naming the thread..from my view,the engine was run hard and fast.Hard enough to create heat,fast enough,long enough to pound out the center bearing..Or Kevin is correct in a failure of process when pouring the babbit.I can tell by looking at the assembly it was done by a skilled hand.Is there a point in the babbit process where the actual composition of the babbit can be compromised?or is it as simple as contamination of the tinned bearing cap prior to pouring? |
07-11-2017, 08:07 AM | #8 |
Counterweights are to stop the crankshaft from wanting to bend (whip) due to the heavy weight off the centerline of the crankshaft. This is one of the Model A's shortfalls.
Adding counterweights doesn't mean you need to lighten the flywheel, and I don't plan to lighten mine when I add the weights I bought from Dan Price. You are right that the added weight will help dampen vibrations. That failed babbit may have been a bad mix or poured at the wrong temp, etc. |
07-11-2017, 08:20 AM | #9 |
I ran a full weight flywheel with a VW engine I balanced and counterbalanced.I was cautioned against it by the speed folks but found a fantastically smooth running engine,shifts smoother too..the extra mass improves drivability. I plan on using two single barrel down drafts,touring cam.mechanical advance distributor and high compression head in this build so a little 'zip' loss is acceptable to me..
I've seen videos of babbit pouring,they used a torch to flow the babbit..is their a proper temp to pour at? do they use a kiln to heat it? |
07-11-2017, 08:29 AM | #10 |
I also went with welded counterweights instead of a chinese crank..too many failure of SCAT cranks in the VW world,Wolfsburg metalugy.like Rouge metallugy is superior..does anyone sell a welded counterweighted A crank?or do you have to buy the weights and get them done?
07-11-2017, 03:53 PM | #11 |
I've had a welded counterweight crank crack. I'm not sure whether it was caused by the welding weakening the crank or by poor regrinding with ineffective radii?
I've now got a Burlington crank installed and so far no problems despite some members suggesting concern over the quality of the material. The motor cruises at 60mph doing 1670rpm with the 41% F150 gearbox overdrive. Keith |
07-11-2017, 04:50 PM | #12 |
FWIW, Ford produced a counter balanced crank for the A for use in grain body trucks.
They were run full out racing to get the grain to the silos for best profit. They were shrunk on weights. The inner weights were a larger ID then the outer weights. They were heated and put in place and left to cool. They were not welded. |
07-11-2017, 05:23 PM | #13 |
Pre-detonation ?
There is pre-ignition and detonation. Two different critters. Who do you think does the best babbitt work on the east coast ? |
07-11-2017, 05:42 PM | #14 |
Schwalm's/Ora Landis
07-11-2017, 05:48 PM | #15 | |
Service Bulletins or Service Letters. How about a part number or blue print. Bob |
07-11-2017, 07:17 PM | #16 |
If anything, the two photos in this posting are a great illustration of the versatility of poured babbitt bearings. The crankshaft looks fine yet it was running on a fragmented skein of failed babbitt. Hard to believe, but true.
07-11-2017, 07:44 PM | #17 |
A complete VW engine would be lighter than a Model A flywheel?
07-11-2017, 07:58 PM | #18 |
Running a full weight flywheel with a counterbalanced crank on my 31 tudor. It runs great! I agree with Tom on this.
07-11-2017, 09:57 PM | #19 |
Its a consensus. I spoke to a friend and he agrees with Kevin in NJ.It appears the failure is totally related to the babbit not adhering to the tinning. I'm still in good shape,I've got a good basis for repair,the engine has low hours on the build,I can save the cam and valve train,and not need to get the seats cut..Crank is probably still good,Ill have to measure it out.Block has been hot tanked and painted with glyptol.
Once I pull the pistons and measure the bores Ill know if it needs to be cut,If i get lucky I'll hone and ring it.. I might just get away with cutting for insert bearings and build,not bad for a few hours of fabrication eh? |
07-11-2017, 10:03 PM | #20 | |
I could fill pages with photos of failed chinese crankshafts.. just say the word.. |
