10-24-2017, 09:44 AM | #1 |
Hood attachment on Fenderless roadster
Good Morning. I picked up a really nice hood and will be running without fenders. Where or how should I install the Latches and will I need the hood shelves? I never thought to look on the cars I've seen with a hood. Thanks, Greg
10-24-2017, 10:21 AM | #2 |
Re: Hood attachment on Fenderless roadster
How about them Leather Hood Straps? Some Guy made his, from some OLD Cowboy Belts & hung Saddle Bags on his DOOR!
Bill Racy
10-24-2017, 10:50 AM | #3 |
If using the hood side-panels, use the stock latches. They may require a spacer under them? If not using the side panels, you can buy leather straps and special springs that look really cool. I run no side panels and use stock latches with brazing rod extending from hood to latch. It's a modified car, use your imagination.
10-24-2017, 11:19 AM | #4 |
Greg,
GOOGLE images is yr friend. For expert advice we would have to see photos of the speedster. Chris |
10-24-2017, 11:50 AM | #5 |
old leather belts from a thrift store make good hold downs.
10-24-2017, 12:14 PM | #6 |
10-24-2017, 12:46 PM | #7 |
Something like this?
10-24-2017, 04:02 PM | #8 |
Right again ZZ. need to attach to frame rails. Not even sure what the Shelves do, I believe they are used to attach to fenders?
10-24-2017, 10:10 PM | #9 |
Stock hold downs bolted right to frame rail mounting holes....
10-24-2017, 11:00 PM | #10 |
Thanks Welsh! That is awesome. Nothing to prevent rattle and vibration? I will just bolt on latches to frame?
10-24-2017, 11:35 PM | #11 |
That's all I have 2 latches each side....working pretty good so far....I do have rubber stops but haven't needed them so far!
10-24-2017, 11:51 PM | #12 |
Here's mine with springs and straps.
10-25-2017, 07:45 AM | #13 |
Sorry Greg. I should have added also, that yes they are mounted directly to the frame rails. Like Welsh stated. Better picture.
10-25-2017, 08:11 AM | #14 |
Greg,
Is your car 28-29 or 30-31? Mine is 29 and I needed to have spacers to get the latches to reach the hood, so I made custom covers to hide the wood blocks. I will try to get pictures. Jerry |
10-25-2017, 10:47 AM | #15 |
Greg, Look at my profile album on my speedster. You will see how my hood looks and the latch's. Afordman31
10-25-2017, 02:20 PM | #16 |
Thanks everybody! Great pis of some cool cars!
