09-01-2015, 01:29 PM | #1 |
Carb Jets
Have been running rich with a 65 jet in my flathead 6 cyl. Installed a 60 and still plugs have build up of carbon. Any advice or help appreciated.
Paul |
09-01-2015, 01:42 PM | #2 |
Re: Carb Jets
That's a pretty drastic main jet change. You probably have an issue with a high fuel level form a sinking float or other reason, like the power valve/jet leaking or hanging open, or leaking fuel valve and seat.
Also, did you clean the plugs before you re-evaluated after the jet change ? Once the plugs get black like that, it takes forever to clean up while driving. Sal |
09-01-2015, 01:50 PM | #3 |
Re: Carb Jets
So I'm assuming this is a G and trouble is something other than main jet! I don't know anything about the 2 carbs or how they vary. |
