Old 08-09-2021, 03:39 PM   #1
dean333
dean333's Avatar
Send a message via Yahoo to dean333
Default 59AB Crab distributor plug wiring routing
What is the proper plug wire routing to clear the fan belt? Thanks!
Tim Carlig
dean333 is offline   Reply With Quote
Old 08-09-2021, 05:33 PM   #2
dean333
dean333's Avatar
Default Re: 59AB Crab distributor plug wiring routing
I answered my own question. I initially laid the cables outside the wire looms/tubes to see which length went to which plug. Once I fed the cables thru the tubes I see how they clear the fan belt. I thought it would be a b@:;: to feed the cables thru but they slid right in.
Tim Carlig
Old 08-09-2021, 05:44 PM   #3
drolston
drolston's Avatar
As long as you don't make the mistake of getting 9mm cables instead of 7mm, they generally go through pretty easy. A little wD40 helps.
Old 08-09-2021, 07:25 PM   #4
dean333
dean333's Avatar
drolston, set is from C&G Ford parts.
Tim Carlig
Old 08-11-2021, 01:28 AM   #5
dean333
dean333's Avatar
One more question, how does the power feed to the generator route, alongside the spark plug cable tube on the outside?
Tim Carlig
Old 08-11-2021, 10:14 AM   #6
Bill OH
Generator wires feed thru the conduit along side the ignition wires (field and armature) and while your doing all of that run a ground wire thru the conduit to connect the generator and the regulator together for ground. I am assuming you are using a two brush generator. If your generator is a three brush, then you have only one wire to run thru the conduit to connect the generator cutout and the battery. You can also use silicone spray to assist in feeding the wires thru the conduit.
Bill OH is offline   Reply With Quote
