Old 10-05-2016, 03:36 PM   #1
Corn Fed
Corn Fed's Avatar
Default 32 parts
City: State Center
State: IA
Price: 40-500
SOLD .. 32 Ford K-member with both legs. Everything is straight and there are no modifications. The LH side of the cross member and the front mounting pad of the same leg have some heavy pitting in some areas (caused by the battery?). I personally would use it as is, or you could repair if it really bothers you too much. $450 plus shipping.
32 Ford lower rear window section. This came from a Sedan, but it could probably be used to fix a Coupe as well. $70 plus shipping.
32 Ford above rear window roof section. The tack strip area is in good shape.This came from a Sedan, but it could probably be used to fix a Coupe as well. $35 plus shipping.
32 Ford Fordor door jamb post. It doesn’t appear that there is a difference in LH or RH for these, it looks symmetrical.Maybe it could be used in a Coupe or Tudor in a pinch?Lower end is rusted and top has been chopped. $45 plus shipping.
M/O only, no PayPal.
Will trade for nice steel 32 front fenders, 32 sedan or PU rear fenders, 33 hood sections, 33-4 sedan rear fenders, magnesium 5-spoke rims.
Corn Fed is offline   Reply With Quote
Old 10-19-2016, 08:22 AM   #2
Corn Fed
Corn Fed's Avatar
Default Re: 32 parts
Bump up with lowered prices.
