06-21-2021, 04:46 PM | #1 |
1934 Ford Ignition switch key and door key
Was the Ignition switch key and the door lock key was the same? Also how do you rekey the Ignition switch, do not have a key.
06-21-2021, 06:08 PM | #2 |
Re: 1934 Ford Ignition switch key and door key
Originally they were the same key code and therefore the same key worked for both. In order to re-key the ignition/steering lock cylinder, it will have to be removed and sent to someone with the skills to make the change such as 32phil on this site. Better yet, send him the door lock cylinder and key as well. For sure send him both if you have no working keys for either lock.
06-22-2021, 06:04 AM | #3 |
There are several posting on this site about how to remove a ignition lock cylinder and the door cylinder. The lock cylinders have key codes stamped on their bodies.
06-22-2021, 10:00 AM | #4 |
1934clint call me and I will walk you through removing the locks without hurting them.
my cell 845 551 5132 Phil
Early Ford Lock & Key Service https://www.fordbarn.com/forum/showthread.php?t=46583 |
06-22-2021, 04:44 PM | #5 |
