#1 |
I have a 1954 F250 with the marking plate on the glove box. I was able to locate the last 6 digits on the frame so can confirm the frame matches the VIN in the glovebox. The title I have list the VIN as L04609265. This came from the title my grandfather had when he bought the truck around 1956.
Does anyone know where that L number could have come from? I thought it might be on the engine but from what I've read online for the Y-Block, none of the identification numbers start with L. |
#2 |
To further clarify, the vin in the glove box matches the standard format of F25XXXXXXX so I know that is the correct VIN but I'm trying to figure out where the "L" number could have come from so I can connect the title to the truck.
#3 |
I found this online but you're right, the letters don't work out.
http://www.vanpeltsales.com/FH_web/F...3-55trucks.jpg |
#4 |
In what position is the L in the VIN NO. reading from the left?
- WANNA SEE A GOOD CAR WRECK? - https://www.youtube.com/watch?v=5oO226PgSkg KULTULZ - HAS MOVED ON TO THE HAPPY PROVING GROUNDS |
#5 |
It is exactly as posted: "L04609265" on the title. I've searched the engine as I've been told it could be the located there but have not been able to find it.
#6 | ||
#7 |
If you are in CA. Find the two VINs that match.
Have a statement of facts ( this stated who what where you got the car from) and a bill of sale from a family member. And have the car title fixed to match the VIN like most modern registrations and titles. In CA it's a pain but worth it later on. In other states it seems to be something you can go to your local DMV and have the verification done and corrected. |
#8 |
What is stamped on the frame rail is a PARTIAL VIN.
There was no VIN (partial) used on an engine until 1968. As mentioned, you need to have the TITLE updated. Now are you still wondering what the L is for? |
#9 |
My 57, 61 have frame stamps. On the passenger side near or above the A-arm. I'd you dont see the whole thing. You might have to wide brush a little.
I believe also at the upper rear section of the frame. On a truck your have to take the bed off. Some states also assign new numbers. |
#10 |
Old post with actually photos way at the bottom. https://www.ford-trucks.com/forums/9...estions-2.html
#11 |
Thanks everyone, looks like I am going to have to get a bonded title to get the VIN fixed.
#12 |
Sometime it help to know what state you reside in?
I fixed the VIN on and old hand me down classic, With the help of a VIN verifier and the AAA DMV. |
