10-30-2015, 04:41 PM | #1 |
body numbers?
my motor number is not on the engine(removed) im guessing because it is a replaced engine. I found the briggs tag under the floor board. where will i find the ford serial on the frame? I have a number on the title that reflects november 29 its a fordor. with 1930 bumpers and oval 29 cluster.
10-30-2015, 05:02 PM | #2 |
Re: body numbers?
The number on the frame is on the driver's side under the cowl.
10-30-2015, 05:25 PM | #3 |
Re: body numbers?
inside or out side? i have to wait till tommorow when i can look if it was at the house i would have already been out there.
10-30-2015, 06:24 PM | #4 |
Re: body numbers?
Look at the info on the below threads
https://www.fordbarn.com/forum/showth...=engine+number https://www.fordbarn.com/forum/showth...=engine+number post #18 https://www.fordbarn.com/forum/showth...+number&page=3 post #48 https://www.fordbarn.com/forum/showth...=engine+number post #3
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
10-30-2015, 07:13 PM | #5 |
Re: body numbers?
10-30-2015, 08:02 PM | #6 |
Re: body numbers?
