Old 09-10-2015, 01:58 PM   #1
hardtimes
hardtimes's Avatar
Default door strap install pics....Q
Would someone please post pic (s) of proper (Ford's way) way that the door straps should look when installed. My driver does not have these straps and I'm now about to install some. None of catalogues that I have show these installed.
Old 09-10-2015, 02:32 PM   #2
Charles Coe
Charles Coe's Avatar
Default Re: door strap install pics....Q
What year and body style is your car? Not all models used the straps.
Charles Coe is offline   Reply With Quote
Old 09-10-2015, 05:30 PM   #3
hardtimes
hardtimes's Avatar
Hey Charles,
Yup, my bad !
It is my '30 Roadster. There are 4 stainless flat/rectangular pieces with 2 holes each. Are all four used or ?
Old 09-10-2015, 06:16 PM   #4
Charles Coe
Don't have a roadster so no picture but there should be one on each end of both straps.
Old 09-10-2015, 07:06 PM   #5
d.j. moordigian
d.j. moordigian's Avatar
Originally Posted by hardtimes View Post
Hey Charles,
Yup, my bad !
On the straps,...at each end? Then, yes..
d.j. moordigian is offline   Reply With Quote
Old 09-10-2015, 08:21 PM   #6
hardtimes
hardtimes's Avatar
Thanks guys, got it !
Old 09-10-2015, 10:35 PM   #7
Randy in ca
Randy in ca's Avatar
The straps gets doubled over on both ends - here's a picture of a 1930 Deluxe (Marco's)
File Type: jpg 1930 Ford Deluxe Roadster DOOR CHECK STRAP.jpg (28.1 KB, 132 views)
Randy in ca is offline   Reply With Quote
Old 09-11-2015, 12:10 PM   #8
hardtimes
hardtimes's Avatar
Hey Randy,
TNANKS much...that's why picture was asked for !
I got them on, but did not look right with the 2 extra holes ..not filled.
It is going to be a bit of a task 'doubling' the ends up, as the leather is very THICK.
Old 09-11-2015, 01:08 PM   #9
Tom Wesenberg
Tom Wesenberg's Avatar
Originals weren't leather, so I wonder if it's even possible to double them up?
Old 09-11-2015, 02:04 PM   #10
hardtimes
hardtimes's Avatar
Precisely ! So, neoprene wasn't around then,eh ? So, maybe faux (naugahide ?) hide or rubber ?
Oh well, I just went out to look at them installed again. Since the doors open even wider with straps installed with widest set of holes...looks great !! Like is oft said here , by some, if it is ain't broke why fix it
Hm, wondering if vendors offer a rubber substitute version to do same job ?
Old 09-11-2015, 02:22 PM   #11
700rpm
700rpm's Avatar
If it's not for judging but just for service, I suggest woven belting in an appropriate color. I used that on my 28 RPU driver and it worked well and looked fine. I guess I would have to admit that it was "good enough."
Ray Horton, Portland, OR
