Old 01-08-2019, 12:24 PM   #1
Cool Hand Lurker
Cool Hand Lurker's Avatar
Default Overdrive in 47 Coupe
Are there adapters to mate a 49-53 overdrive up to a 59A block?
Cool Hand Lurker is offline   Reply With Quote
Old 01-08-2019, 12:32 PM   #2
Bob C
Default Re: Overdrive in 47 Coupe
It would be easier to use a 1949-E51 Mercury trans,no adapter needed both require open drive.
Bob
Old 01-08-2019, 01:05 PM   #3
G.M.
I prefer a Columbia 2 speed rear that's made to
fit. G.M.
www.fordcollector.com
Old 01-08-2019, 01:29 PM   #4
Cool Hand Lurker
A Columbia might be a little hard to find and more high-buck than I can handle.
Old 01-08-2019, 05:43 PM   #5
TJ
TJ's Avatar
Put in a Mitchell. Much cheaper than a Columbia and more durable.
Old 01-08-2019, 08:19 PM   #6
Cool Hand Lurker
Have heard a lot about Mitchell but not looked into it. Where do they mount in the driveline, and does the torque tube have to be altered?
Old 01-08-2019, 08:27 PM   #7
cas3
the wider/late columbias like you would use on your coupe are the most common and cheapest. if you just shift manually with a fuel valve as many do, and not have all the real controls, they are around
Old 01-08-2019, 10:25 PM   #8
4dFord/SC
4dFord/SC's Avatar
It comes with its own torque tube: http://mitchelloverdrivemfg.com/prod...v-8-overdrive/
4dFord/SC is offline   Reply With Quote
Old 01-08-2019, 11:43 PM   #9
Ol' Ron
Ol' Ron's Avatar
I prefer the Mitchel as well. It's a modern unit and trouble free. The Columbia, unless rebuilt and strengthened can be a problem
Old 01-09-2019, 12:43 AM   #10
Drbrown
Drbrown's Avatar
Here's my Borg-Warner R10 mounted in the enclosed driveshaft, 8 inches in front of the banjo. At best, rare as hen's teeth. There's a 90 yr old guy in Ohio that use to fab these. For all I know he's still at it.
Drbrown is offline   Reply With Quote
Old 01-09-2019, 09:58 AM   #11
Planojc
Planojc's Avatar
Mitchell is the way to go. Easy to install.
Planojc is offline   Reply With Quote
Old 01-09-2019, 11:42 AM   #12
Cool Hand Lurker
Thanks for all the replies. After checking the cost of doing this project, I have decided to just drive my coupe like it is now. Thanks again.
Old 01-09-2019, 11:46 AM   #13
Ol' Ron
Ol' Ron's Avatar
There is another option. Convert to open drive rear axle, and dozens of transmissions become available.
Old 01-09-2019, 02:02 PM   #14
4dFord/SC
4dFord/SC's Avatar
Another option is a 3.54 rear end.
Old 01-09-2019, 08:18 PM   #15
Cool Hand Lurker
I do have a good 53 Ford rear axle that I could use but it would also require the later springs and it has a smaller bolt circle for the rims. I would still need an adapter plate to mate whatever transmission up to the 59A block. The older I get, the more likely that the project will never get finished. And at 80, I want to DRIVE !
Old 01-10-2019, 08:28 AM   #16
Frank Miller
Frank Miller's Avatar
Probably not cheap either but keep your eye out for an LZ overdrive. I think this was the bog warner but had the end for the torque tube.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 01-10-2019, 10:14 AM   #17
TJ
TJ's Avatar
At 80 you should spend your money. Enjoy what's left. "Ain't no pockets on a casket".
Old 01-10-2019, 12:44 PM   #18
Cool Hand Lurker
Talking Re: Overdrive in 47 Coupe
Yup. Last winter I had the engine rebuilt and also converted to tube shocks. Just spent the money, but it was hard to let somebody else do it. This winter it is off to the upholstery shop for new interior, new windows and new weatherstripping. Cha-Ching!
The toughest thing for me with getting old is accepting the fact that I probably won't get a major project done by myself anymore. And those are the most expensive ones! When you have spent all your life fixing used stuff instead of buying new it is hard, really hard, to fork out cash to have somebody else screw it up. I still want to screw it up myself !!!!
Old 01-10-2019, 04:48 PM   #19
supereal
supereal's Avatar
I have a Ryan 3 to 1 OD in my '47. I am not sure they are still made. I use mine on the highway only. A word of caution: if you do lots of highway driving, but sure that the brakes and handling are in top shape, and that you have a "third" stoplight installed. I live two miles from I-80, but try to stay off in my '47. It simply isn't safe to mix old vehicles with today's traffic and try to stay at the usual 70-80 mph required.
supereal is offline   Reply With Quote
Old 01-10-2019, 09:31 PM   #20
Cool Hand Lurker
That is a good idea, Super. I had to drive this one home along I-80 from a little town in South Dakota. I kept it at about 50mph not knowing how it would go, and I got passed by a lot of cars. Most of them were courteous and I got a lot of 'thumbs up' but it was a light traffic day. The suspension is in good shape but still it is stock with no rack & pinion, radial tires, disc brakes, etc. so SLOW is good enough and safer. But it would still be nice to cruise at any speed and have the engine at a comfortable speed too.
