Old 09-22-2021, 07:27 PM   #1
GB SISSON
GB SISSON's Avatar
Default Old School Parking brake fixture for stretched cable
I tried searching for this but Mr. Google doesn't seem to remember the JC Whitney/ Western Auto gadget that clamped onto a stretched cable to 'shorten' it. Probably got outlawed. Seen them on the old wrecks I drag home. Do they still make them?
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson)
Old 09-22-2021, 08:23 PM   #2
51504bat
51504bat's Avatar
Default Re: Old School Parking brake fixture for stretched cable
GB, I may have one in my stash. I'll check and let you know. If I do its ours for postage.
Old 09-22-2021, 08:33 PM   #3
GB SISSON
GB SISSON's Avatar
It's actually for my '92 F350. I have had the rear axle mostly apart with new brakes, seals etc after a roadside disaster with perhaps too many beams on the load. Everything works well now, but no matter what, the parking brake doesn't grab until that far left pedal is about a 1/2" off the floorboards. Thanks! A simple device, just puts a kink in the cable to use up length.....
Old 09-22-2021, 09:41 PM   #4
corvette8n
corvette8n's Avatar
Gary: Rockauto see pic, I think the hook/bolt is in backwards in the picture, I may order one to have on hand.
https://www.rockauto.com/en/parts/do...adjuster,10479
Also carried by advance auto and Oreilly and eBay.
https://www.oreillyauto.com/detail/c...ter/mtm0/03006
File Type: jpg 073A6E9A-6C9A-4D6A-9648-D73CBF62DA5B.jpg (15.5 KB, 50 views)
Old 09-22-2021, 10:14 PM   #5
bobH
If necessary, 'gang' them. I think my old truck has at least two of them.
bobH is offline   Reply With Quote
Old 09-22-2021, 10:33 PM   #6
GB SISSON
GB SISSON's Avatar
Sooo Funny!!! and yes the foreign dudes that assembled the thing for the picture got the hook in backwards. Would work fine once reversed, but the ones I've seen have a cast serpentine shape re-routing the cable. I like your's better. OK, to be honest here, my 47 tonner which made a good wood run today had the same problem and in a pinch I cut a couple inches outa the cable and then took a 12" piece of wire rope and cable clamped with 3 clamps each side, a splice that drew the cut ends together. It's a Very good parking brake, but with the '92 running thbe interstate and licensed/insured with my business I thouught it best to do it right. Well , sort of right. Gonna go to Rockauto! I see on Amazon that Dorman has some interesting ways to go about this ...
Old 09-27-2021, 02:33 AM   #7
Bruce of MN
Bruce of MN's Avatar
Can you link to the Dorman items?
Old 09-27-2021, 03:35 AM   #8
V8COOPMAN
V8COOPMAN's Avatar
Dorman #03006, available at O'Reiley's, etc! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 09-27-2021, 10:32 AM   #9
GB SISSON
GB SISSON's Avatar
So, are we all in agreement that the hook in the photo is installed backwards?
Old 09-27-2021, 11:29 AM   #10
JSeery
JSeery's Avatar
Yep, the two nuts are used to adjust and tight the J-hook and go either side of solid part at the end where the hook is now. The J-hook needs to be between the studs to pull on the cable.
Old 09-27-2021, 07:16 PM   #11
Yoyodyne
Yoyodyne's Avatar
Yes, pretty sure that's just so it can't separate in shipping.
Interesting, I've always just seen them double nutted on the outside. I can see your point though.
Yoyodyne is offline   Reply With Quote
Old 09-28-2021, 04:47 AM   #12
big job
big job's Avatar
I bought a couple last year from Napa and asked this thing is backward he said yes that's for packaging.
big job is offline   Reply With Quote
