Old 03-01-2015, 02:33 PM   #1
pgerhardt
pgerhardt's Avatar
Default Which would you use?
I am sitting here looking at snow falling outside AGAIN, and thinking of spring. I'll be swapping out my current distributor (with modern points and condenser on the upper plate) for a rebuilt one with the stock point system. I have the choice of two distributor body/caps. I have an old (but still in good shape) Ford script body/cap that I picked up at swap meet years ago. I also have a NORS brown body/cap which would add a little color to the engine compartment. So which do you think would be coolest?
pgerhardt is offline   Reply With Quote
Old 03-01-2015, 02:56 PM   #2
dumb person
dumb person's Avatar
Default Re: Which would you use?
The brown one.
<Link> This is how we roll<Link>
"I'm Convinced that no one really reads posts anymore; they just fabricate what they think the post says then ramble on about red herrings."--Bob
Outcasts rules of old cars
#1 Fun is imperative, mainstream is overrated
#2 If they think it is impossible, prove them wrong
#3 If the science says it impossible you are not being creative enough.
#4 No shame in recreating something you never had
#5 If it were not for the law & physics you would be unstoppable
dumb person is offline   Reply With Quote
Old 03-01-2015, 03:06 PM   #3
C26Pinelake
Why the brown one ?
Wayne
C26Pinelake is offline   Reply With Quote
Old 03-01-2015, 03:27 PM   #4
ronn
OK then, the black one...................
Old 03-01-2015, 03:44 PM   #5
31 Model A
31 Model A's Avatar
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
Bakelite items in other fields are worth more when the item was in brown. Don't know about this though. I'd go with the black..............for looks.
"Bullshit and Brilliance Comes with Age and Experience"
"Hey Lady, ya wanna buy a Grit?"
"If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers
31 Model A is offline   Reply With Quote
Old 03-01-2015, 03:45 PM   #6
bikejunk
I run a brown NOS as well, for the last 2,500 miles so far, really nice quality ,
bikejunk is offline   Reply With Quote
Old 03-01-2015, 04:21 PM   #7
C26Pinelake
Originally Posted by dumb person View Post
The brown one.
Originally Posted by 1930 coupe View Post
I would run the one that fits the best on the distributor and has the best rotor to contact gap. Also run both of them at night in the dark and look for stray sparks.
Now that is a sensible reply ! Thanks, Wayne
Old 03-01-2015, 04:45 PM   #8
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
You mentioned a brown NOS one. Did Ford actually make a brown one?
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 03-01-2015, 04:49 PM   #9
Juggler
Juggler's Avatar
English ones are brown
Juggler is offline   Reply With Quote
Old 03-01-2015, 05:01 PM   #10
Fred
Ok, Neither of what you show are for your car.. The "Brown One" is a After Market Reproduction one.. The "Black One" has a After Market Script Base.. The Coil Wire Tower Top is "Original Ford", But only used in Early 1928..
Fred is offline   Reply With Quote
Old 03-01-2015, 08:10 PM   #11
pgerhardt
pgerhardt's Avatar
No. I said NORS New Old Replacement Stock. It is photographed on the box of the company who produced it back in the day.
Old 03-01-2015, 08:31 PM   #12
pgerhardt
pgerhardt's Avatar
Fine point judging aside, I would think that either could have been found on my 29 tudor in 1929. I believe that since the brown one is made of Bakelite not a modern plastic it is most likely a period replacement while a 1928 distributor body/cap could have easily sat on a dealers shelf until 1929.
In any event using the one that functions the best seems like the best and most helpful advice.
Old 03-01-2015, 08:43 PM   #13
Dusty
Dusty's Avatar
Do they make them in green?
Dusty is offline   Reply With Quote
Old 03-01-2015, 08:49 PM   #14
Tom Wesenberg
Tom Wesenberg's Avatar
No, but you could spray paint them silver to see if the paint really contains any metal.
Old 03-01-2015, 08:56 PM   #15
ODFever
ODFever's Avatar
Check both with an ohm meter. I do not know what the reading should be to determine if it's good or not, but someone here on FB might know. Pick the one that works. I'm sure you'd rather drive your car rather than being stranded on the side of the road.
ODFever
1930 Ford Model A Town Sedan "Alyssa"
ODFever is offline   Reply With Quote
Old 03-01-2015, 09:01 PM   #16
pgerhardt
pgerhardt's Avatar
LOL! I hope that coupe has been in at least one Saint Patrick's Day Parade!
Old 03-01-2015, 10:31 PM   #17
glenn in camino
glenn in camino's Avatar
Originals have only one notch to locate in the distributor base,
Old 03-02-2015, 12:01 AM   #18
tbirdtbird
ohms should be zero
'31 180A
tbirdtbird is offline   Reply With Quote
Old 03-02-2015, 12:36 AM   #19
MikeK
MikeK's Avatar
Originally Posted by tbirdtbird View Post
ohms should be zero
Following up on that thought, checking across terminals with a megger (high voltage insulation resistance tester) is also helpful. I have found several beautiful original dizzy bodies that fail internally, reading only a few thousand ohms, when I set my megger on 1KV. Checked with a standard battery powered ohmmeter they appeared fine, reading infinity between terminals.
MikeK is offline   Reply With Quote
Old 03-02-2015, 02:34 AM   #20
Dusty
Dusty's Avatar
No buy I'm working on that.
