09-10-2015, 11:46 AM | #1 |
Ideal Street & Touring Speed Equipment Setup
What are your opinions regarding equipment and changes for turning a stock Model "A" into 1930s street banger?
As soon as my 190A restoration is done later this year, my 1931 Coupe will start a transformation to a 1930's era street banger. My Coupe already has a Model "B" engine. Here are my thoughts about changes for the Coupe: > 6:1 compression cylinder head with a steel McCord gasket; > Reground Model "B" camshaft for more torque in the 2000 to 3000 motor rpm range; > Single downdraft Model 94 carburetor with stock Ford V8 jets power valve; > Mallory YA11 Distributor with dual points & centrifugal advance; > 12-volt electrical system with at least a 60-amp alternator; > Pertronix 40611 coil with 12V primary & 40,000 volt secondary; > Walker radiator pressurized @ 3 to 6 psig; > Electric radiator cooling fan; > Coolant overflow retention tank; > Electric coolant pump; > TT10 Spark Plugs with 0.027" gap; > 1932 18" Ford wheels with 5.50-18 tires at 28 psig; > Modern telescoping shocks; > Flathead Ted's brake floaters; > 1932 radiator shell; > Lightened flywheel & V8 clutch; > Stock Model "A" transmission & 3.78:1 differential.
Bob Bidonde |
