08-23-2023, 11:49 PM | #1 |
28/28- 30/31 Roadster installation kit difference
I'm mounting the windshield on my 29 roadster, and having an issue with the way it fits. It seems that suddenly the windshield seems too wide-
When I mocked everything up I used a crusty original windshield, I'm also using a pair of original stanchions.. the stanchions are stock height, but raked back a little- this way it fit perfectly . All this fitting was done before final paint etc.. now that the car is going back together I'm having these issues.. aside from chrome & paint the only difference is for the final assembly I'm using a new windshield, it's stock height ford oem replacement , and the size is dead on. I'm also using a new pair of tapered cups... i suspect the new cups are a little off. unfortunately I don't have the old ones anymore to compare the new ones too. Is there a difference between 30/31 and 28/29 windshield instalation kits, specifically the tapered cups, and the nuts that hold the cups to the studs? Thanks in advance! |
08-26-2023, 08:30 AM | #2 |
Re: 28/28- 30/31 Roadster installation kit difference
Hello, I read the repro cups don’t fit as well as original ones , big surprise,can’t say whether the cups are the same, windshield and stanctions are completely different of course from 28-9 and 30-31 . Hopefully others will join in.
08-26-2023, 10:03 AM | #3 |
That's what I was figuring as well.. speaking with the fellow at Synders confirmed my suspicions. New *better* cups were ordered.. I also noticed that there is quite a bitbof paint on the upper part of the cowl that the posts fit over. I'll sand that all back as well and see what that get me..
I'll be sure to.post my results. |
08-26-2023, 03:18 PM | #4 |
