Old 08-24-2022, 02:15 PM   #1
macdonge
macdonge's Avatar
Default Need generator advice
Electrical gurus please chime in. I bought a recently rebuilt 2-brush generator and set it up on my engine test stand to check it out (after polarizing per the usual procedure). It didn't appear to be charging so I brought it in to a local shop for testing. They called a while ago to say it charges just fine (up to 30 A output)... but only if it's run CCW!
Ideas?
macdonge is offline   Reply With Quote
Old 08-24-2022, 02:21 PM   #2
supereal
supereal's Avatar
Default Re: Need generator advice
Like many others, I installed an alternator on my car. It eliminated the old voltage regulator, and handles heavier loads of bright headlights and accessories.
supereal is offline   Reply With Quote
Old 08-24-2022, 03:05 PM   #3
Brian
Brian's Avatar
Are the field wires reversed?
Old 08-24-2022, 05:31 PM   #4
macdonge
macdonge's Avatar
My thinking was that didn't matter, i.e. the polarizing exercise would take care of that.
Old 08-25-2022, 08:28 AM   #5
ndnchf
ndnchf's Avatar
Is this a positive ground car? The generator needs to be polarized to match the system.
ndnchf is offline   Reply With Quote
Old 08-25-2022, 04:02 PM   #6
macdonge
macdonge's Avatar
Negative ground. I think I’ll try re-polarizing & reinstall it.
Old 08-25-2022, 06:05 PM   #7
Karl Wolf
Karl Wolf's Avatar
You could check it by seeing if it motors.
Hook up a live battery to the armature connection, and the field
to positive side of the battery. Connect the negative side of the
battery to the generator body- ground. The generator should spin.
Karl
Karl Wolf is offline   Reply With Quote
