Old 09-02-2016, 09:01 PM   #1
warren va
Default My 40 ford Jumping out of high gear
I have been driving my car for over 10 years with no problems. Today it started jumping out of high gear into neutral. Does this call for a readjustment of the shifting linkage and if so some advice please.
Thanks
Warren
warren va is offline   Reply With Quote
Old 09-02-2016, 09:17 PM   #2
fordcragar
fordcragar's Avatar
Default Re: My 40 ford Jumping out of high gear
It could be adjustment. What I would do is put it in third gear and then raise it up into the air. Then pull the linkage on the second/third gear lever, now see if you can move the lever farther into gear. If it isn't the linkage, it could be either the shifting fork or a gear.
When it is popping out of gear, that is usually an indicator that it isn't going all the way into gear.
fordcragar is offline   Reply With Quote
Old 09-03-2016, 09:10 AM   #3
rotorwrench
rotorwrench's Avatar
High gear depends on the synchronizer assembly since it is direct drive. When things get worn and there is too much play in there, it can pop out. It is important to maintain the detents in the shifting mechanism though. They do some of the job of keeping things in mesh. It may be time for an overhaul.
Old 09-03-2016, 09:20 AM   #4
warren va
Thanks fordcrager for your reply. I'm Checking it out today and will let you know the results.
warren va
Old 09-03-2016, 07:24 PM   #5
warren va
Today I extended the shifting rod another 1/4 inch for third and second gear. Then drove it up and down hills, braking a lot and in start and stop traffic in town. So far it has not disengaged again. Got my fingers crossed and knocking on wood.Hope this will solve my problem.
Thanks again to you both
warren va
Old 09-03-2016, 07:49 PM   #6
alanwoodieman
check the condition of the rubber grommets. worn or loose (oil soaked) grommets will contribute to the problem. glad you do not apparently need to rebuild trans!!
Old 09-04-2016, 04:32 PM   #7
George/Maine
George/Maine's Avatar
The ujoint bolt maybe looseing and shift is moveing to back.
George/Maine is offline   Reply With Quote
