Old 01-10-2012, 02:50 PM   #1
Camden
Default Transmission identification
Maybe someone could help me id the year on a couple of transmissions i have.
One has a serial # 1ga314772 this has shift levers on the side of case. The other has shifter on the top,the shift handle is bent back after it leaves the tower then has another bend back up 5 or 6 inches from the knob. Serial # 18-4256394. Thanks
Camden is offline   Reply With Quote
Old 01-10-2012, 03:11 PM   #2
Lawson Cox
Lawson Cox's Avatar
Default Re: Transmission identification
Get Mac Vanpelt's transmission book.
Old 01-10-2012, 03:29 PM   #3
Mart
Mart's Avatar
1938 85 HP top shift.
1946 ford 6 90hp. side shift.
Google mac van pelt and look at his web site under serial numbers.
Luckily the trans has the serial number of the vehicle it was fitted to, so is easy to check.
Mart.
Old 01-10-2012, 09:27 PM   #4
Mike in AZ
Mike in AZ's Avatar
here's the link to the serial numbers on MacVP's website....lots of good info on other parts of the site....good luck and have fun....Mike
http://www.vanpeltsales.com/FH_web/f...ialnumbers.htm
Mike in AZ is offline   Reply With Quote
