Old 03-14-2018, 06:02 PM   #1
1930artdeco
1930artdeco's Avatar
Default sealing rain gutters
Hi All,
The wood my rain gutters are attached to is start to degrade. So, what I want to do put some sort of sealer (silicone, rubber cement etc.) just on the top where they meet the body. This way it will hold them in tightly and force any water into the gutters and not let it get through to the wood. Any suggestions besides the two above?
Thanks,
Mike
1930 TownSedan (Briggs)
1957 Country Sedan
Old 03-14-2018, 07:03 PM   #2
J Franklin
J Franklin's Avatar
Default Re: sealing rain gutters
An auto glass shop has a sealent for bedding glass that should fit the bill. They have a needle tip for forcing it under the rubber lip of glass channel. Try them out
Old 03-14-2018, 09:10 PM   #3
Tacoma Bob
Tacoma Bob's Avatar
Was just introduced to a great product called big stretch. NON silicone. Current thinking is against the use of silicone around paint finishes.
Tacoma Bob is offline   Reply With Quote
Old 03-15-2018, 06:15 AM   #4
desotoguy
May want to check out an automotive seam sealer. Comes in a caulking tube, and can be painted.
desotoguy is offline   Reply With Quote
Old 03-15-2018, 08:50 AM   #5
Kurt in NJ
Kurt in NJ's Avatar
There are different seam sealers, and different colors too, some one part, brush on in a paint can, some in like a toothpaste tube, and 2 part epoxy sealer with double gun to dispense--- how permanent do you want it
Usually can get tan, grey, black in different brands
