01-05-2018, 08:48 AM | #1 |
'31 Roadster p/u top question
Working on getting the top on the '31 Roadster pickup we are putting together.
Bought the Cartouche top with plastic back window. I need to obtain the "studs" that go in the top of the back panel to hold the bottom of the top down. This top does not have a center flap that can be pulled up. It appears the holes in the cab are threaded. What is the proper name of the "studs" that I am looking for, and are they readily available from the typical Model A vendors? They are not the "Lift a Dot" fasteners, just the open holes. Thank you. DEW |
01-05-2018, 12:57 PM | #2 |
Re: '31 Roadster p/u top question
Here is what I have on my '31 RDPU. I put them in 40 years ago so I can't swear they are correct or why I chose them. I would try Le Baron Bonney, (800) 221-5408.
Charlie Stephens |
01-05-2018, 01:03 PM | #3 |
Tony Hillyard a fellow Barner here. Made a YouTube video on Model A top installation.
Do a search for that. Very well done, as well as informative. Good luck. Jeff |
01-05-2018, 01:22 PM | #4 |
They are called "clinch style wood screws". Most all vendors carry them in various sizes.
If at first you don't succeed, skydiving isn't for you! You don't need a parachute to skydive, you only need a parachute to skydive twice. |
01-05-2018, 02:47 PM | #5 |
Thank you all very much!!
Charlie that looks like exactly what I need, thank you for the picture. jthomas6 thank you for the correct name. I found them at Snyder's. |
01-06-2018, 04:24 AM | #6 | |
http://www.snydersantiqueauto.com/cinch-studs
I Love Anything That Turns Money Into Noise |
