Old 02-28-2017, 12:27 PM   #21
Neil Wilson
Neil Wilson's Avatar
Default Re: CCPU Rear View Mirror
Originally Posted by wrndln View Post
Rex,
I believe the picture you posted, that I have seen before, was of an early pickup - sometime in 1928. If your pickup had date stamp in mid March 1929, I don't think your pickup would have a visor mounted mirror like in the picture. Your cab without mirror mounting D nuts is a real mystery.
Rusty Nelson
Not a mystery to me. Most 82-A closed cabs that I have seen into March 1929 do not have the D-nuts and therefore would have had the sun visor mirror bracket. I had a March 1929 AA which was like that.
Given the RGJS indicates late 1928 as the startup for the D-nuts, then there was an overlap of bracket usage. The cab of the vehicle determine which bracket was originally used. If it were up to me (which it was not), I would say that early 1929 was when the D-nuts started.
[email protected] - email contact
https://aafords.com Ford Model AA Truck Club @ aafords.com
Neil Wilson is offline   Reply With Quote
Old 02-28-2017, 12:41 PM   #22
SeaSlugs
SeaSlugs's Avatar
I see - not bad at all!
1929 Model AA - Need long splash aprons!
SeaSlugs is offline   Reply With Quote
Old 02-28-2017, 12:43 PM   #23
Neil Wilson
Default Re: 82-A Side View Mirror
Originally Posted by CarlG View Post
Neil,
Is there a hinge mirror similar to the one Snyder's sells (see link in post #4) with a longer arm?
Ford didn't provide a over-the-hinge mirror bracket for the 82-A. The 82-B (starting June 1930) came with an over-the-hinge mirror bracket. Ford did have longer over-the-hinge brackets for the 82-B. I don't think anyone is making them.
Old 02-28-2017, 12:56 PM   #24
Neil Wilson
Default 82-A Side View Mirror
Rex,
I didn't know Neil made parts (or had them made) for AA and CCPU's. That is nice to know. The mirror bracket is a little pricey but at least it is available. I have never seen the parts in your link to Neil's website in any model A catalog.
Rusty
Pricey is correct. I got 15 of these brackets made out of Sicilian bronze, got them machined, had the swivel balls made, and then had the swivel balls installed. I will not get any more made (a couple left) - folks just don't want to spend the $'s.
I also got the earlier bracket made the same way (see http://sell.aafords.com/aa-parts-for-sale/#82a-mbd1). These were only used for the AA's through February 1928.
These brackets are almost never found at swap meets.
Old 02-28-2017, 01:53 PM   #25
CarlG
CarlG's Avatar
Neil,
Originally Posted by Neil Wilson View Post
...Ford did have longer over-the-hinge brackets for the 82-B. I don't think anyone is making them.
Any idea what length the hinge brackets for the 82-B were/are? I was thinking about having a couple of the shorter ones lengthened.
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 03-01-2017, 05:05 PM   #26
Neil Wilson
See attached.
Old 11-06-2017, 08:46 AM   #27
Rex Perry
What is the preferred method for removal of the threaded bar that secures the mirror fasteners? I thought that mine was missing but it apparently dropped down when someone removed the sun visor.
I would like to remove this little part and recondition it. My top is off and I have open access to the RH and LH corners. I could remove the horizontal plate riveted to the top of the post but would prefer another method. Suggestions?
Thanks
Rex Perry is offline   Reply With Quote
Old 11-11-2017, 09:27 AM   #28
Rex Perry
Normally the nut bar is welded inside the forward door post. If, for some reason, those welds fail the nut bar can drop down the door post behind the window escutcheon. In my particular case, the head of one of the 1/4x20 screws had been twisted off leaving the remainder in the nut bar. With that broken screw remaining in the bar, it was trapped by internal structure and could not slide down behind the escutcheon.
Old 11-11-2017, 10:58 AM   #29
Neil Wilson
The tapping block (i.e. nut bar) was used prior to D-nuts and seem to have frequently broken loose (as in your case). See hinge pillar designs d1, d2, d3 and, d4 at http://aafords.com/aa-body-types/bod...s/mirrors/#pib.
I have made/replaced the tapping block used at the sun visor and also lower on the hinge pillar.
As I recall, I held the tapping block in place with bolts before welding it to the inside of the pillar with a wire feed welder (not an easy place to weld).
Old 11-11-2017, 01:11 PM   #30
Rex Perry
Neil,
The procedure that you outline is exactly what I did but I had to compromise on the lower weld as the bottom was not accessible. Poor welds is probably what contributed to so many failures but pushing hard on the screw heads during removal is also a factor.
Old 11-11-2017, 11:06 PM   #31
Neil Wilson
Neil,
After several years of see hinge pillar holes without threads, I found a tapping block which had broken loose. At that point, the non-threaded holes made since.
Old 11-12-2017, 12:50 PM   #32
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
Originally Posted by Tom Wesenberg View Post
Trucks had no inside mirrors as I understand it.
TRIVIA: The first "documented" use of a rear view mirror was on a YELLOW, 1912 Indy 500 race car
Bill Reflection
"THE ASSISTANT GURU OF STUFF"
Old 11-12-2017, 01:21 PM   #33
1930-Pickup
Is this the bracket for the 82-B? It doesn't say anything about length though.
https://www.modelaparts.com/a17704a
File Type: jpeg 0000788_a17704a-truck-hinge-mirror-1930-31_550.jpeg (70.9 KB, 3 views)
"That's my wild unsubstantiated guess, and I'm sticking to it regardless of the facts!"
1930-Pickup is offline   Reply With Quote
Old 11-12-2017, 03:10 PM   #34
denis4x4
denis4x4's Avatar
Here is my ‘29 with D inserts on both sides.
File Type: jpg 4E59152B-79D7-4963-BB46-9FCF0D3C2E2F.jpg (39.2 KB, 28 views)
No restorable Model A's were harmed in the building of this truck!
denis4x4 is offline   Reply With Quote
Old 11-12-2017, 06:09 PM   #35
Neil Wilson
The on-hinge brackets used for the AA's are shown in the photo. For a 1930 A-chassis with an 82-B cab, bracket A-17741-B was used (top image in the photo).
Old 05-05-2022, 12:55 PM   #36
charlesatto
Neil Wilson,
What is the center to center measurements of your mirror mounting bracket?
charlesatto is offline   Reply With Quote
Old 05-05-2022, 02:12 PM   #37
ndnchf
ndnchf's Avatar
This is an old discussion. But I'll throw this in for general interest. My early '31 CCPU has an original drivers side hinge mount mirror. The arm is 5.5" long. I have the original mirror, but replaced it with a new convex mirror for much improved visibility.
ndnchf is offline   Reply With Quote
Old 05-05-2022, 11:28 PM   #38
CarlG
CarlG's Avatar
I changed mine out for convex mirrors as well. Bumped them up to 6" as well. Big improvement.
Alaskan A's
Old 05-06-2022, 08:07 AM   #39
Neil Wilson
Originally Posted by charlesatto View Post
Neil Wilson,
charlesqtto, Sorry, I don't know what mirror bracket you are referring to? The measurements shown in the photo of response #35 above may answer your question.
FYI — I do not have any of the mirror brackets shown in the photo to sell.
Old 05-06-2022, 10:31 AM   #40
katy
katy's Avatar
Ditto
