07-07-2014, 01:39 PM | #1 |
Rassling fenders
I'm working on fenders, off of the car. It's like wrestling hogs!
I'm wondering if any of you has invented some kind of frame to fasten the fenders to while you work on them. At this point, I am doing the metal work. A frame would be good for the painting, too. Any advice would be appreciated. Thanks, Royal |
07-07-2014, 03:29 PM | #2 |
Re: Rassling fenders
Most body shops have a "X" frame that has webbing to hold it open, Kind of like a folding chair design. Has foam padding on the pipe to prevent marring of your bodywork and they can paint on them. Look on Craigslist or even Harbor freight for it.
Barry 50 F-1 |
07-07-2014, 03:40 PM | #3 |
I use an old folding picnic table. The fender lays flat and doesn't walk off like it would with a rack. Made a rack once and it wasn't a good idea. Use welding "C" clamps to hold it in one place on the table.
07-07-2014, 04:04 PM | #4 |
I use a couple of pieces of wood mounts to the fender and then mount the whole thing to an engine stand. Then you can roll it over.
07-07-2014, 04:06 PM | #5 |
I do fender repair work on the vehicle. That way you know you are getting everything lined up as it should be.
07-07-2014, 09:54 PM | #6 |
Low tech all the way.
Louvering, bias ply tire-truing, metal shaping and forming, lathe and mill work, member shop HAGERTY Ins. expert repair network. High quality paint work in Iowa. |
07-07-2014, 11:38 PM | #7 |
I'm with John Worden on this one. I have saw horses all over the place & you can stack one on top of the other if they ever get empty. Heh heh he
07-08-2014, 08:12 AM | #8 |
I dont have pictures but I have seen a jig at a local shop that uses vise grips welded to a length of rod, the rods attach to a base via a machined ball(its been a while since ive seen it) the guy who built it was a machinest that was having his car worked on. I know this is pretty vague.
07-08-2014, 04:17 PM | #9 |
I agree. Sometimes you spend hours on end and get the fender looking just right only to find out that it is off just "so much" here and there once you mount it and then have to start over. I gave up and worked on mine on the vehicle.
Matt 24:36-41 |
07-08-2014, 04:53 PM | #10 | |
Torchie. |
07-08-2014, 06:41 PM | #11 |
Trial fitting during repair/straightening is an important step.
It's just that some damage is physically impossible to reach on a car mounted panel.
07-10-2014, 04:24 PM | #12 |
Thanks for some really good ideas.
Royal |
07-11-2014, 06:40 AM | #13 |
Good advice from several above posts. Re. Rassling with Hogs comment - Reminds me of an old saying - "Arguing With a Parts Man, is like Rassing with a pig in the mud - After awhile, you realize the Pig likes it." ...
