03-08-2011, 11:16 AM | #1 |
Protection from fire in 36 ford
Hi Barners,
Some time back there was an article, I think in the Early Bird magazine, on how to protect your car from fire. They put a 30 amp Circuit Breaker between the Solenoid and a wire that is the source for ALL electrical power except for the Battery Cables. Is there any logical spot to put such a safety device on a 36 Ford? I am putting a Master Shut-off Switch between the Negative battery cable and the floor starter button. Thanks for any ideas. Bruce/Ct [email protected] |
03-08-2011, 12:48 PM | #2 |
Re: Protection from fire in 36 ford
Put the master switch in the ground cable,When it is off nothing is hot. If you put it in the hot cable everything is hot up to the switch when it is off.
Bill |
03-08-2011, 04:19 PM | #3 |
Disconnect the ground cable from the battery and save yourself a lot of work. I never leave my cars sit over nite without disconnecting the battery cable and I have all new wiring.
03-08-2011, 06:07 PM | #4 |
03-08-2011, 07:35 PM | #5 |
Hi Paul,
Is the what directed at my initial question or one of the replies? I will clarify if you wish. Bruce/CT |
03-08-2011, 08:05 PM | #6 |
If you put the switch in the hot cable going to the starter switch that cable is hot as well as the terminal on the back of the switch and the terminal on the battery. Bill |
03-08-2011, 09:58 PM | #7 |
When I disconnect the battery, I always disconnect the ground cable. You do that and no electricity anywhere
03-08-2011, 10:57 PM | #8 |
Protecting wires is all well and good but how do you protect against carb. fuel fires? This is what happened several years ago with the hood up.
03-09-2011, 09:42 AM | #9 |
You had to have a spark somewhere, so, check the wiring.
03-09-2011, 11:10 AM | #10 |
03-09-2011, 11:25 AM | #11 |
Was it the accelerator pump leaking? I had a similar problem with a 390cfm Holley, but luckily had a fire extinguisher handy. Glad that you are all better now. Joe
Joe. |
03-09-2011, 01:30 PM | #12 |
I must be missing something here. If you're going to install a Master Disconnect Switch, why would you put it anywhere but directly off the battery. Regardless of which terminal you select, you are breaking the circuit to or from the power source. Paul Selfe.
03-09-2011, 04:25 PM | #13 |
Paul,
My reason is there is not enought space under the floor for an Optima 6 volt battery Reasons: 1. My reason is there is not enought space under the floor for an Optima 6 volt battery. A post mounted switch would make it higher yet 2. Getting to the shut-off in an emergency under the floor mat and battery box cover would be very slow Bruce/Ct |
03-09-2011, 04:48 PM | #14 |
Dumb mistake by the cars owner (me). After changing jets, the cross over fuel bowl tube was not properly seated in the rubber 'O' ring.
