06-06-2019, 09:20 AM | #1 |
Strictly Competition Ford/Lincoln/Mercury/Edsel V8
Fuel injection and magneto.High compression, 10.5 and up.
When I was going at it big time a few years ago, a little birdie told me stay away from Holley electric high pressure fuel pumps. If something goes wrong it can turn into a big old fire problem! Just a word to the wise about going with fuel injection. Same thing.Fuel injection systems like Hillborn use a high pressure mechanical fuel pump. That fuel will come out of there REAL FAST if there is a leak of some kind. High compression means race gas or nitro mix only! Those little pings you hear with low octane gas are bad news for the engine.That's called 'detonation'.It will destroy all those nice parts in the engine you lovingly assembled with your own little hands. So basically a full house engine is limited to what we used to just call a 'trailer car'. Dragster of some kind.Slingshot or altered, whatever. Road race car but no nitro for those and mag not necessary. Have fun!
'Has racing made you a millionare?' 'Yes it has.Before I was a multi-millionaire.'-Quote Last edited by all american boy; 07-21-2019 at 10:55 AM. |
06-06-2019, 10:07 AM | #2 |
Re: Full House Ford OHV V8
Used to see the fuel injection intake manifolds at the swap meet for cheap.
Couple problems with going that route. Then you will need the Hillborn fuel pump to go with it. Setups I've seen drive off of the motor somehow and that means hassle. Like I said, when I was going at it I just 'stayed in the boat'. Looked into a few things like this and found out they had a lot of 'gotcha's' to them. Only for tube frame type race cars where everything is easily accessible. They do put out a worthwhile increase in power though! Get a deal on the WHOLE SETUP that somebody pulled off a running engine or you will get nickled and dimed to death getting rest of parts. Have fun!
'Has racing made you a millionare?' 'Yes it has.Before I was a multi-millionaire.'-Quote |
06-06-2019, 10:26 AM | #3 |
Those old mechanical fuel injections also only work well at a certain rpm. Usually the pill is set for high rpm and are lousy at lower revs.
06-08-2019, 11:33 AM | #4 |
'the pill is set for high rpm'
Don't know what a 'pill' on a Hilborn injection system is but Hilborn's are for racing.Okay with me. In our little world the limit is going to be two four barrel carb's. We can do that on the MEL 430 but it's a waste of time on a Y block. Y block will only take up to 4 two barrels on log manifolds. That's from our little 1959 How to Hop Up Your Engine book. Back to Hilborn. Found out those little spun aluminum tanks are made to be PRESSURIZED! Always wondered about that.
06-08-2019, 11:39 AM | #5 | |
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
06-08-2019, 11:48 AM | #6 |
Going to make one. Tin box open plenum.
'Has racing made you a millionare?' 'Yes it has.Before I was a multi-millionaire.'-Quote Last edited by all american boy; 06-09-2019 at 09:16 AM. |
06-08-2019, 01:04 PM | #7 | |
Pill is the same as a jet in a carb. Regulates the fuel flow. Problem with the mechanical injectors is they are really made for racing so you set the pil (jet) for the high rpms which means very rich at low rpms. Not to good on the street. I know Hilborn makes EFI setups now but at $7000 a tad pricey. |
06-08-2019, 05:20 PM | #8 |
'really made for racing'
Still okay with us.No more 'door slammer's' for us. Don't have the patience anymore to work on things with stuff in the way. Mentioned the two four barrel setup because that will be our 'fuel injection' setup.Keep in the spirit of a 'maximum effort' race setup without the expense. Probably won't go with a mag either. Just putting the engine in a light tube frame you come out miles ahead. See what the engine can really do in a 1,250 pound car. Drag pipes make a big old difference. Our new saying is 'Trailer car or no car!'. That's from 'Mopar or Nocar'.
'Has racing made you a millionare?' 'Yes it has.Before I was a multi-millionaire.'-Quote Last edited by all american boy; 06-08-2019 at 05:37 PM. |
07-17-2019, 12:13 PM | #9 |
I have been "shown". Across the street from me in Seal Beach, California, the young son was building an Econorail and I saw him tacking welds on the chrome moly tubes. I had been to Fullerton JC and took gas welding from an old pipeline welder. He was going to have it arc welded later. He had purchased a former chrome tube axle from a "Top Fuel dragster." His engine had parts from Moroso which his dad knew. I sent my tools to Nicaraugua in 1987 with the medical supplies and a disc drive and some IBM Selectrics. In 1998 I got hit by a car in a cross walk with the green walker and the car had a red left turn arrow. Just got called out as a spammer by Vintage Ford. How am I doing, here? My 1976 BMW 530i had a Bendix designed and Bosch supplied Luft not Kurz. The Chevrolet stock FI used a float bowl that looks like from a Rochester 2GC. My room mate cornered the market on FI's and T-10's that had been taken off in 1965. He put one he rebuilt on his 1967 truck.
07-17-2019, 12:21 PM | #10 | |
07-17-2019, 01:12 PM | #11 |
Badass is talking 'train of thought'.
The econorail hits me where I live. Building a 440 econorail was on the list when things got side tracked a little. Now we are basically doing same thing just with parts rearranged some. Guy learning to weld from a super experienced welder is like the guy that welded our Pro Stock car together.He learned as a deep water welder in the Navy. Those welds were a thing of beauty.He threw in extra touches we did not even asked for.THAT was a welder! Full house OHV V8. Yep.Do it the RIGHT WAY!
07-21-2019, 10:58 AM | #12 |
Pressurized fuel tank.
Small fuel tank with a hand pump. ROCKIN' GOOD NEWS! Here is how it works. Tank & pump Fuel filter Shut off valve Fuel regulater Pressure gauge ( motor mounted or instrument panel in cockpit) Carb/carbs/fuel injection This competition only is getting better all the time!
'Has racing made you a millionare?' 'Yes it has.Before I was a multi-millionaire.'-Quote Last edited by all american boy; 07-21-2019 at 12:01 PM. |
