Old 08-18-2019, 07:16 PM   #1
Marcus
Marcus's Avatar
Default A/C in 68 Mustang
Gentlemen: About to install a Vintage Air SureFit A/C unit in a 1968 Mustang Convertible, strong and healthy 289, C4 - local "experts" say no problem with 100% stock radiator; Vintage Air says "probably" no problem; really don't want to take unnecessary chances with the car overheating, so what are your thoughts? High dollar replacement radiator? Auxiliary electric fan? Or??
WARM REGARDS, MARCUS
Marcus is offline   Reply With Quote
Old 08-18-2019, 07:43 PM   #2
paul2748
paul2748's Avatar
Default Re: A/C in 68 Mustang
Since no one has said it won't work, I would try it with the stock radiator and go from there.
48 Ford Conv
56 Tbird
54 Ford Victoria
Old 08-18-2019, 07:49 PM   #3
miker98038
miker98038's Avatar
If I’m reading about the right unit when I google it, it says
“2. We recommend using our heavy-duty fan blade and shroud”.
My experience with heating problems in a 55 bird (and others, with and w/o ac) is the fan and shroud are a big deal. My other thought would be what did a factory a/c option use for the fan and shroud. That said, if the local guys say it’ll be fine, I’d try it before I got carried away spending money on items you don’t need. If something is already going bad, then I’d do the upgrade as part of the install.
Does it come with an electric fan for the condenser?
miker98038 is offline   Reply With Quote
Old 08-19-2019, 04:20 AM   #4
JeffB2
JeffB2's Avatar
Wouldn't hurt to add this anyway,not a big expense. https://www.ebay.com/itm/1967-1969-M...8AAOSwIzpdWNok
JeffB2 is offline   Reply With Quote
Old 08-19-2019, 07:17 AM   #5
Ford blue blood
Ford blue blood's Avatar
To be 100% (or as close as possible) sure you're not going to have "heating" problems look at a "bigger" radiator, fan, and shroud. Most heat issues are air flow related followed by coolant volume. The stock radiator in that car is small with respect to volume. Adding a three core will increase volume. A shroud will help move air through the radiator at idle and low speeds. New cars cool all day long with a little bitty radiator, they use every inch of the fins by very strict air control, that and the computer richens up the mixture to aid with temperature control.
Bottom line after having said all of that....if it ain't loosing water it ain't overheating. Some people get a little excited about water temperature. An old school hot rodder friend always said his car was running hot. After looking and trying to make it boil the hottest it would get was 190. Turns out he thought "normal" temps were 160 - 170 and anything higher was "over heating".
Bill, certified Ford nut.
2016 F-150
2016 Focus
08 Shelby GT500
57 Ford Ranchero
36 Chevy, 351C/FMX, 8", Mustang II
Ford blue blood is offline   Reply With Quote
Old 08-19-2019, 09:19 AM   #6
5851a
I don't believe Ford ever put AC in a car without a fan shroud. Many of the aftermarket fitters of the day would skip that part. Unibody Fords of that age didn't have much room for air to get out of engine compartment a shroud helped keep air from going back forward.
5851a is offline   Reply With Quote
Old 08-19-2019, 11:04 AM   #7
Alaska Jim
Alaska Jim's Avatar
If you do install a shroud, be sure to correctly position the fan. the fan blades should be half way ( half of the blade centered ) in the shroud opening. if it is not in far enough, or in to far, you are defeating the purpose of having a shroud.
Alaska Jim is offline   Reply With Quote
Old 08-19-2019, 07:08 PM   #8
Marcus
Marcus's Avatar
All good advice, and thank you. I should have added that it has the factory stock fan shroud and fan.......I'm inclined to follow the preponderance of advice and just do the installation: see what develops from there!
