Old 11-20-2019, 07:55 AM   #1
rockfla
rockfla's Avatar
Default Spark plug preference...Curious
IS there a preferred "Brand" spark plug for your flathead? What prompts the question is my best friend is a "Willys" guy and all the guy's on his support page prefer the Champion J8 for the Willys Jeeps!! They say they run best with them.....SO before I go buy a new set.... is there a particular brand like "Champion that is preferred say over Autolite??? Flathead in question is a 1939 Merc.
Old 11-20-2019, 08:04 AM   #2
mfirth
Default Re: Spark plug preference...Curious
NGK or Autolite for me.....some folks are not happy with Champion quality.
mfirth is offline   Reply With Quote
Old 11-20-2019, 08:28 AM   #3
Bored&Stroked
Bored&Stroked's Avatar
I use only NGKs
Old 11-20-2019, 09:22 AM   #4
V8COOPMAN
V8COOPMAN's Avatar
Fifty + years ago, the only thing I ran in several "go-fast" Chevies was Champs. As time went-on, the Champs became more and more prone to fouling. Later in the early '80s and to this day, I had some STOCK, factory hi-horsepower Corvettes that were all impossible to keep Champs running clean in. Changed to Factory-type AC plugs and the little Chevies love 'em. I've had the same bad results with Champs in my flatheads. Only Autolites for me any more. I know that "Kiwi" is gonna hate me for chastising his Champions. Just my experience! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 11-20-2019, 09:43 AM   #5
flatford8
flatford8's Avatar
I use Autolite #216 in a stock motor. I’ve had the electrode pull right out of the porcelain when I pulled the wire off on two plugs. As of now,I haven’t changed to another brand.....Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 11-20-2019, 10:42 AM   #6
rockfla
rockfla's Avatar
Would that be the NKG 7131???
Old 11-20-2019, 11:19 AM   #7
Bored&Stroked
I use a NGK B6L when I need a 7/16 reach plug. They work well on both street and high-performance flatheads. Part number is 3212.
Old 11-20-2019, 11:33 AM   #8
rockfla
rockfla's Avatar
It's Dead stock 39 Flathead.
Old 11-20-2019, 11:49 AM   #9
19Fordy
19Fordy's Avatar
I use NGK # GR4 2635 plug with 11/16 reach on MCF heads vintage 1999.
That was the plug suggested by Mark Kirby of MCF.
Old 11-20-2019, 12:05 PM   #10
flatheadmurre
flatheadmurre's Avatar
I also went to NGK for 2 reasons....first they have never so far failed in mysterious ways for no reason...and i can buy them in bulkpack for a reasonable price.
Old 11-20-2019, 12:07 PM   #11
mfirth
1940, are you 12 volt Or 6 positive earth ?
Old 11-20-2019, 12:26 PM   #12
rockfla
rockfla's Avatar
For the 3rd time, STOCK. 6V system, positive ground. Original 39 Mercury engine....NO aluminum heads, NO high performance JUST STOCK. AND numbers sure help a fellow, I've got 3 different NKG numbers, 3212's seem to be the one (Thanks Bored&Stroked).....but NKG's web page only has to 1950 SO not sure if an 8BA plug is good for 39 Merc???? The "plug" cross reference page I looked at listed "several" NKG numbers 3212 being one and 3112 being one, not seeing where 7131 is listed for a flathead BUT That is what NAPA's web page shows for a 39 Mercury????
Old 11-20-2019, 12:32 PM   #13
19Fordy
19Fordy's Avatar
I am 12V with negative earth. I use an alternator not a generator.
Engine is 8BA with early style heads.
Old 11-20-2019, 04:20 PM   #14
TJ
TJ's Avatar
I use the Autolite 216's.
Old 11-20-2019, 04:37 PM   #15
AnthonyG
AnthonyG's Avatar
Any pros or cons using a resistor type. I know the newer cars w all the electronics & computers need them but also I’ve used them thinking it prevented radio / stereo interference?
Nomad
AnthonyG is offline   Reply With Quote
Old 11-20-2019, 04:50 PM   #16
Ford Freak
Me too !
Ford Freak is offline   Reply With Quote
Old 11-20-2019, 05:53 PM   #17
TomT/Williamsburg
TomT/Williamsburg's Avatar
I use NGKs 3212 in my more or less stock avatar 40 engine. I like them because you can clean and regap them multiple times before they get tossed. I have never used Champions but had been using Aurolute 216s - more of a personal preference using the NGKs .....
TomT/Williamsburg is offline   Reply With Quote
Old 11-20-2019, 08:04 PM   #18
Karl
Karl's Avatar
NOS 3 piece Champion C7's in my 1934.
20000 miles on the current plugs and still going strong I have a spare (and a half) set if I ever need them. When I got the car it was running Champion D21's . Nothing wrong with them just not original. The D21's are still doing sterling service in my 1910 Hupmobile-Bearing in mind that the fire is lit in this by a an early HT Bosch magneto -If the plugs aren't tip top you would know pretty quickly
Such a fine sight to see-Its a Girl, My Lord, in a Flatbed Ford slowin' down to take a look at me.
Karl is offline   Reply With Quote
Old 11-20-2019, 10:23 PM   #19
Ronnieroadster
Ronnieroadster's Avatar
The best choice of plug for your Flathead as others have mentioned is the NGK B4L or B6L the NGK plug works perfectly for stock as well as modified applications being 6 or 12 volt neg or positive ground has no effect over the spark plugs performance. The Autolite 216 is a second choice but is in no way as good as the NGK . Champion plugs being made in mexico are prone to failure so what ever you do stay away from that brand. Ask your NAPA salesman for the B6L plug no need to try and figure out the part number.
Ronnieroadster.
I use the F word a lot no not that word these words Flathead , Focus and Finish.
"Life Member of the Bonneville 200 MPH Club using a Ford Flathead block"
Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline.
First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH
Ronnieroadster is offline   Reply With Quote
Old 11-20-2019, 10:29 PM   #20
Ronnieroadster
Never use a resister type plug with a 6 volt system their design is for much more modern ignition systems the original flathead systems do not fall into that category. In other words not enough coil potential to get a good spark with 6 volts
Ronnieroadster
